So I got a package in the mail Saturday:
Woohoo! 23 sheets if 1/4" BB!
Unfortunately, I had already made my first plate rim (1/4 ply not the bb ) and plate stand (from 3/4 pine) - should have used 1/4" on the stand :(
Made my first plate today (unfinished) - stack cut 2 1/8" ply so I have an extra waiting for a new rim.
Now I have my first plate - waiting for finishing and a backing
Waiting for the rim and finishing then backing and mounting
One thing is certain - these fretwork pieces can really be a PITA having to remove and insert the blade over and over - I don't see how you guys do those really detailed fretwork pieces.
Better saw. Many times the saw will be the key to enjoyment. The easier it is to do and undo a blade will be a factor. This is one of the reasons that top end saws are pushed so much. When you start getting into production work all aspects of cutting and working with the saw come into play. We do not push those saws because we have interests in the companies. The amount of room under the saw is also important especially if you have large hands.
You are doing fine and the more you do this the more little tricks you will learn on your own. Hopefully someday you can step up to a better saw and really enjoy the fun. For now take your time and keep having fun.
First, congrats on you delivery. It's always good to have lots of material. You seem to be moving right along with your projects. Second, no matter what you do enjoy it. If your not enjoying it then move on to the next. That's probably why I do so many different projects. I feel that if I do the same thing day after day I'm not gaining anything. Something new is always refreshing.
  • 4 weeks later...
Real nice work! Looks like you've been scrolling for quite a while!!
Do you have any problems using plywood? I seem to have a splintering issue with plywood......I've been using a 1/4 inch poplar wood from Home Depot. Only problem is that the widest width is only 6 inches......
Thanks, I've been scrolling for a very long month and half LOL - seems like forever!
I no longer use ply from the box stores - it's really low grade.
I get my ply from ebay and it's very good B quality ply - here are the 2 I get
https://www.ebay.com/itm/1-8-3mm-x-12-x-12-Baltic-Birch-Plywood-for-Laser-CNC-and-Scroll-Saw-40-pc/351972469846?hash=item51f331ac56:g:EKcAAOxyxnJR6A4O
https://www.ebay.com/itm/1-4-6mm-x-12-x-12-Baltic-Birch-Plywood-for-Laser-CNC-and-Scroll-Saw-23pc/272247092328?hash=item3f6330f468:g:EKcAAOxyxnJR6A4O
7 hours ago, Scrappile said:
Looks to me like you are well on your way.  Where did you order the BB from?  I am going to have to look at ordering, it is getting really difficult to find a good grade of BB locally.
Thanks, I'm getting my good wood from
http://ocoochhardwoods.com/plywood.php
And my ply from
It comes sanded (I still do a light sanding of 60, 150 and 220 before cutting) and get plenty in a box
It's also nice that if I screw up a project, I'm only out $1.25 or $2.40 rather than $30 or more - ply is very expensive here and good ply is no where to be found
Edited by new2woodwrk
