3Dface Posted February 19, 2018 Report Posted February 19, 2018 i am having a blast with this stuff. i asked what it might be called in another post and a nice member said it might be "layering". i searched and found that layering was stacking separate thin, mostly 1/8" layers of wood following a pattern then adding the picture/drawing to the layers then gluing the layers together. this "3D cover?" is a comic book cover glued to 1/2" plywood, planning and cutting the cover into "puzzle pieces?" then using the layers of the plywood to adjust depth and hot glue each piece back into the body of the cover. very few of the pieces go back in "straight and level". for example all of the arms in this cover are made flush with the body of the subject and farther out at the hands to create more depth. in any case i love doing it and have been lucky enough to sell a few to help pay for stuff to make more. the last picture is a jig i made to hold the body of the project to make reassembly much easier. jbrowning, Lucky2, Roberta Moreton and 3 others 6 Quote
DWSUDEKUM Posted February 19, 2018 Report Posted February 19, 2018 Very nicely done. Thanks for sharing this with us. DW 3Dface 1 Quote
Scrolling Steve Posted February 19, 2018 Report Posted February 19, 2018 Neat !...That's thinking outside the box ! 3Dface 1 Quote
GPscroller Posted February 20, 2018 Report Posted February 20, 2018 Cool idea, thanks for sharing. Jeff 3Dface 1 Quote
newfie Posted February 20, 2018 Report Posted February 20, 2018 Nice work thanks for sharing 3Dface 1 Quote
WayneG Posted February 21, 2018 Report Posted February 21, 2018 very interesting idea! I am intrigued 3Dface 1 Quote
lawson56 Posted February 21, 2018 Report Posted February 21, 2018 Now that is Just Downright Awesome!!I use ot read Morbius whenI was younger.Spidy to. 3Dface 1 Quote
3Dface Posted February 21, 2018 Author Report Posted February 21, 2018 3 hours ago, lawson56 said: Now that is Just Downright Awesome!!I use ot read Morbius whenI was younger.Spidy to. my son is a comic book nut. after seeing a 3D i made of my friends family, it was he that suggested i try covers. stopped yesterday and bought 10 more. i also picked up "the Beatles diary" and will be doing about 15 of the fab four. i can't wait to dig in. thanks for all the cements. makes me feel welcomed. new2woodwrk and lawson56 2 Quote
stoney Posted February 21, 2018 Report Posted February 21, 2018 Outside the box and interesting a very good combination. Thank you for showing us. Keep em coming. 3Dface 1 Quote
new2woodwrk Posted February 21, 2018 Report Posted February 21, 2018 Very cool - can't wait to see the Beatles stuff - I'm searching for that stuff now! 3Dface 1 Quote
Lucky2 Posted February 22, 2018 Report Posted February 22, 2018 Nicely done Chris, it looks fantastic. Welcome to the Village, I look forward to viewing more of your work. And I'm sure there's a proper name for this type of scrolling, but I don't think it is called layering. If it is, then layering has changed from what it was once recognized as in the scrolling world. Layering is when you actually cut numerous layers, and stack them on top of each other to make a scene/picture. I've seen this type of cutting before, but the pieces were cut at an angle. They were cut that way,so that they could be moved forwards or back into the scene. It looks as if you cut your pieces at 90*, how do they stay in place with cutting them that way? Len 3Dface 1 Quote
amazingkevin Posted February 22, 2018 Report Posted February 22, 2018 On 2/19/2018 at 2:19 PM, 3Dface said: i am having a blast with this stuff. i asked what it might be called in another post and a nice member said it might be "layering". i searched and found that layering was stacking separate thin, mostly 1/8" layers of wood following a pattern then adding the picture/drawing to the layers then gluing the layers together. this "3D cover?" is a comic book cover glued to 1/2" plywood, planning and cutting the cover into "puzzle pieces?" then using the layers of the plywood to adjust depth and hot glue each piece back into the body of the cover. very few of the pieces go back in "straight and level". for example all of the arms in this cover are made flush with the body of the subject and farther out at the hands to create more depth. in any case i love doing it and have been lucky enough to sell a few to help pay for stuff to make more. the last picture is a jig i made to hold the body of the project to make reassembly much easier. I like your ideas!Good job!!!!!!!!!!!!!! 3Dface 1 Quote
3Dface Posted February 22, 2018 Author Report Posted February 22, 2018 (edited) 9 hours ago, Lucky2 said: Nicely done Chris, it looks fantastic. Welcome to the Village, I look forward to viewing more of your work. And I'm sure there's a proper name for this type of scrolling, but I don't think it is called layering. If it is, then layering has changed from what it was once recognized as in the scrolling world. Layering is when you actually cut numerous layers, and stack them on top of each other to make a scene/picture. I've seen this type of cutting before, but the pieces were cut at an angle. They were cut that way,so that they could be moved forwards or back into the scene. It looks as if you cut your pieces at 90*, how do they stay in place with cutting them that way? Len hey len, you are correct that i cut it all at 90*. this allows me to choose the depth when i reassemble. cutting on an angle means the depth would be limited to the angle used. as each piece is cut free from the body i remove them. in this one, the words were cut first, next was spidie and his helper, last was the vampire. once these are out of the body i do secondary cutting. cut off slidie's right arm then separate the 2 of them. the vampire cuts are arms, chest, then head with hair. the hardest lesson by far is hot glue is, HOT! that is the biggest reason for the jig... lol in this Hulk picture you can see a temporary frame to hold the body together sense the cuts also compromised the edges of the cover. the 2nd pic is the back before frame was removed. Edited February 22, 2018 by 3Dface Lucky2 1 Quote
heppnerguy Posted February 24, 2018 Report Posted February 24, 2018 This is a fun twist on things. I have not seen this done before. Nothing I enjoy much more then when I see a new idea come to life, like yours. Keep having fun, that is the most rewarding thing about scrolling to me Dick heppnerguy 3Dface 1 Quote
3Dface Posted February 24, 2018 Author Report Posted February 24, 2018 1 hour ago, heppnerguy said: This is a fun twist on things. I have not seen this done before. Nothing I enjoy much more then when I see a new idea come to life, like yours. Keep having fun, that is the most rewarding thing about scrolling to me Dick heppnerguy thank you sir... i still do portraits for friends and rock stars. but i have 4 covers ready to cut tomorrow. will post when cut. Quote
Scrollchaser Posted February 24, 2018 Report Posted February 24, 2018 A great idea! And, a nice job scrolling. Bill 3Dface 1 Quote
Dave Monk Posted February 24, 2018 Report Posted February 24, 2018 That came out awesome! 3Dface 1 Quote
Scrappile Posted February 24, 2018 Report Posted February 24, 2018 You certainly have come up it a unique way to create pieces. Clever, I must say. Nice work. 3Dface 1 Quote
Ron Johnson Posted February 24, 2018 Report Posted February 24, 2018 Like your idea and work Chris. Your items would look great within a shadow box as well. Keep them coming. 3Dface 1 Quote
