Popular Post Old Joe Posted February 24, 2018 Popular Post Report Posted February 24, 2018 I made this Steve Good "relief" wood spirit a couple of weeks ago, but I was not crazy about the mustache area, as it just too big and too empty. I am planning on making another one with a few changes but I have been busy with other issues.Meanwhile I decided that too much work went into the piece to be so disappointed with an otherwise pleasing piece, so I came up with an easy fix. I stuffed some steel wool in both the mustache and eyebrows. bobscroll, Roberta Moreton, frankorona and 7 others 10 Quote
newfie Posted February 24, 2018 Report Posted February 24, 2018 That came out greatthanks for sharing Quote
oldhudson Posted February 24, 2018 Report Posted February 24, 2018 It sure looks better with your addition. I'd be a bit concerned about it rusting? Quote
GPscroller Posted February 24, 2018 Report Posted February 24, 2018 Good thinking, does make a big difference. Quite an improvement. Jeff Quote
scrollerpete Posted February 24, 2018 Report Posted February 24, 2018 Very nice what is the name of the pattern? Quote
bobscroll Posted February 24, 2018 Report Posted February 24, 2018 What a great idea Joe! It looks real nice! Bob Quote
Old Joe Posted February 24, 2018 Author Report Posted February 24, 2018 1 hour ago, oldhudson said: It sure looks better with your addition. I'd be a bit concerned about it rusting? I thought about the rust issue.I will leave this one inside unless I come up with a coating that would resist rust. Quote
Old Joe Posted February 24, 2018 Author Report Posted February 24, 2018 1 hour ago, scrollerpete said: Very nice what is the name of the pattern? I think Steve just called it Wood Spirit. It is a relief pattern cut out of one 1” board. Not nominal, but a full inch.The outer portion of the cartoon, or ‘spirit’ is cut at about a 4 degree angle so it sits about 1/2” recessed of the board. scrollerpete 1 Quote
Ron Johnson Posted February 24, 2018 Report Posted February 24, 2018 Fine cutting Joe. The steel wool does make a difference and you may in time think of an alternative. Quote
kywoodmaster Posted February 25, 2018 Report Posted February 25, 2018 22 hours ago, Old Joe said: I thought about the rust issue.I will leave this one inside unless I come up with a coating that would resist rust. Hey he is using some of that get rid of the gray stuff to get his youthful brown hair back!!!!!! Quote
Rockytime Posted February 26, 2018 Report Posted February 26, 2018 That's both funny and clever. Quote
amazingkevin Posted February 26, 2018 Report Posted February 26, 2018 On 2/24/2018 at 6:57 AM, Old Joe said: I made this Steve Good "relief" wood spirit a couple of weeks ago, but I was not crazy about the mustache area, as it just too big and too empty. I am planning on making another one with a few changes but I have been busy with other issues.Meanwhile I decided that too much work went into the piece to be so disappointed with an otherwise pleasing piece, so I came up with an easy fix. I stuffed some steel wool in both the mustache and eyebrows. Your on a roll,keep your work coming!!!!! Quote
Lucky2 Posted March 1, 2018 Report Posted March 1, 2018 Nicely done Joe, and the steel wool was a great idea. You should send a picture of it with the steel wool in place to Steve, he probably would like to see it. Did you spray the steel wool to keep it from deteriorating, when I use it on a project I always spray it with hair spray. Len Old Joe 1 Quote
