Rob Posted March 1, 2018 Report Posted March 1, 2018 I just finished this plaque by Sue Mey and tried Jerry's method of applying the glue. Wow, what a timesaver! I'm a convert. new2woodwrk, frankorona, Lucky2 and 3 others 6 Quote
Gordster Posted March 1, 2018 Report Posted March 1, 2018 Beautiful plaque Rob.....I agree with you 100 per cent that Jerry is a genius.what a great idea,especially for a plaque the size of yours.I did one today and spread the glue with my fingers. Rob 1 Quote
new2woodwrk Posted March 2, 2018 Report Posted March 2, 2018 Nice work - thanks for shairng Rob 1 Quote
penquin Posted March 2, 2018 Report Posted March 2, 2018 Looks very nice, well done. jim penquin Rob 1 Quote
rjweb Posted March 2, 2018 Report Posted March 2, 2018 Jerry, looks great what was the idea for glueing, RJ Rob 1 Quote
Rob Posted March 2, 2018 Author Report Posted March 2, 2018 9 minutes ago, rjweb said: Jerry, looks great what was the idea for glueing, RJ Jerry's idea was to spread glue on wax paper with a credit card and drop the cutting onto it RJ. It worked like a charm. Rob Quote
wombatie Posted March 2, 2018 Report Posted March 2, 2018 Great looking cutting Rob. Thanks for giving us a heads up on Jerry's idea. Marg Rob 1 Quote
amazingkevin Posted March 2, 2018 Report Posted March 2, 2018 7 hours ago, Rob said: I just finished this plaque by Sue Mey and tried Jerry's method of applying the glue. Wow, what a timesaver! I'm a convert. excellent scrolling skills!!!!!!!!!!!!! Rob 1 Quote
blights69 Posted March 2, 2018 Report Posted March 2, 2018 Great job on the cut Rob and Jerry very rarely has any ideas or suggestions that are not worth taking note of and I will be trying the wax paper way next time Rob 1 Quote
Dave Monk Posted March 2, 2018 Report Posted March 2, 2018 12 hours ago, Rob said: I just finished this plaque by Sue Mey and tried Jerry's method of applying the glue. Wow, what a timesaver! I'm a convert. It sounds like a good method.......my only concern is if it is not centered perfectly an I have to slide it a bit. Nice job! Rob 1 Quote
Rob Posted March 2, 2018 Author Report Posted March 2, 2018 6 hours ago, Dave Monk said: It sounds like a good method.......my only concern is if it is not centered perfectly an I have to slide it a bit. Nice job! There is that Dave but then again that is the same whatever method you use to apply the glue. Rob Quote
rjR Posted March 2, 2018 Report Posted March 2, 2018 15 hours ago, amazingkevin said: excellent scrolling skills!!!!!!!!!!!!! Compliments from A.K. are the Amazing King of compliments! I do have to agree with him too. Rob 1 Quote
rdatelle Posted March 3, 2018 Report Posted March 3, 2018 Great cutting and another great idea. I'll have to try that. I guess it depends on how much glue you put on the wax paper. Rob 1 Quote
jerry1939 Posted March 3, 2018 Report Posted March 3, 2018 42 minutes ago, rdatelle said: Great cutting and another great idea. I'll have to try that. I guess it depends on how much glue you put on the wax paper. MODERATION!! Get the glue about as thin as you can get it, otherwise it will squeeze out. I drop the cut piece on the wax paper, pick it up, rotate somewhat & drop it a second time. That way you catch any spot where you troweled the glue too thin. 3Dface and Gordster 2 Quote
Lucky2 Posted March 4, 2018 Report Posted March 4, 2018 Nicely done Rob, and yes Jerry is right on the ball. He has a never ending supply of helpful information, and he generously shares it with us all. Len Rob 1 Quote
bobscroll Posted March 5, 2018 Report Posted March 5, 2018 Very nice scrolling there Rob! It looks cool! Bob Rob 1 Quote
Chunkthekid Posted March 5, 2018 Report Posted March 5, 2018 Great cut. Thanks for pointing out Jerry's idea. I hadn't seen that post and it is an issue I haven't quite figured out yet. I will give it a shot on my next piece. Rob 1 Quote
3Dface Posted March 5, 2018 Report Posted March 5, 2018 On 3/3/2018 at 9:54 AM, jerry1939 said: MODERATION!! Get the glue about as thin as you can get it, otherwise it will squeeze out. I drop the cut piece on the wax paper, pick it up, rotate somewhat & drop it a second time. That way you catch any spot where you troweled the glue too thin. i thank you for pointing out jerry's wax paper gluing. do you weight it to dry? does that cause squeeze out? Quote
Rob Posted March 5, 2018 Author Report Posted March 5, 2018 Personally, yes, I do apply weight then remove it and check for squeeze out. Then re-apply the weight and leave it to set. Rob Quote
jerry1939 Posted March 6, 2018 Report Posted March 6, 2018 4 hours ago, 3Dface said: i thank you for pointing out jerry's wax paper gluing. do you weight it to dry? does that cause squeeze out? I usually put on a clamp or 2 to make sure it hasn't/won't move. Apply weight or more clamps. 3Dface 1 Quote
