9 hours ago, JTTHECLOCKMAN said:
Have the same pattern and plan on taking it up a notch. On my list for projects this year. Nice job with it.
Thank you,
If I do this again I might try a bigger insert.. I thought the insert was small for as big as the piece was.. however the clock is also about the size of one of the balls.. so I had mixed feelings with it.. I'd like to see what you make out of that pattern.. Also we was at a restaurant and ordered sandwiches.. they put in a tooth pick to hold the sandwich together.. it was a odd one from the other picks I'd seen.. but I'd also thought the way they was shaped etc. they almost looked like they could be used as cue sticks.. which i contemplated adding to the next one..
Anyway, love to see what you come up with.
