I'm looking at various saws trying to decide which I'll spend my money on and one of the things that concerns me is feeding and tensioning  the blade.
I've read several reviews talking about top feeders and bottom feeds (not catfish LOL), and not sure exactly what is meant.
For instance:
On my Wen, I attach the blade to the bottom adapter and feed it up through the table and then through work piece - does that mean I am bottom feeding?
Would top feeding then mean you attach the blade to the top head then feed it down through the work piece and table and attach it at the bottom?
Most of the videos I've seen seem to be the way I am doing it - if I am a bottom feeder - that is such a weird tern to use on myself LOL
Thanks in advance for clarification
Edited by new2woodwrk
You are "bottom" feeding.  And you are correct about top feeding.  I am a bottom feeder, also known as a Carp!!  Catfish would fit also.  And don't let anyone tell you you are a bad person if you bottom feed, I am a good person who happens to bottom feed.....:roll:  Either way gets the wood cut.
Some saws you can only bottom feed on, like the Hegner, the older Hawks,  some you can do either, like the Excalibur, Seyco, King and DeWalt.
Edited by Scrappile
Yes you are a bottom feeder! All sixteen inch saws (except the EX saws) are bottom feeders. The DeWalt saw, EX type saws and current Delta saw as well as Buston Hawks have a lifting top arm to facilitate top feeding. However, you can still bottom feed if you want on these saws. I started on a Dremel 16" saw. On average, it would take two minitues to chance from one hole to the next. Now, as a top feeder, I can change from hole to hole in about 10 to 20 seconds! The benefit of top feeding is you don't have to lift the board up off the table to feed the blade. Instead, you release the lower clamp, raise the top arm then lower the top arm while lining up the blade to the hole then lower the top arm then reattach the blade to the lower clamp then tension. It's far more easier then it sounds. It does take some time to get to used to it but once you get the hang of it, you will never go back to bottom feeding!
I'm also a bottom feeder.. and think I'm a good person / and hope others feel the same about me.. LOL
Something else to consider on a saw.. is the fact that.. the top arm rises.. and something real nice is a saw where the top arm rises on it's own when the blade is un-clamped.. Might not be an issue for some.. but for me it is..
When I first got my DeWalt 11 years ago.. I hated trying to hold the arm up while trying to feed the blade.. ( many use a block of wood etc.  ) at any rate.. I bought a "jim dandy easy lift" and haven't looked back since.. My Hawks both have the spring loaded upper arm.. break a blade.. the arm pops up and doesn't keep running trying to stab you hand until you get it shut down, LOL...
My Excalibur you have to lift and lower the arm manually.. it does stay up on it's own.. but is annoying to me to have to manually do this with each cutout.... I love the Excalibur.. but also do have two complaint about it as well.. One being the manual arm movement. the other is the blade is out near the end ( front ) of the table way closer than my other saws.. doing larger work makes your work piece hang way out off the table.. Not a issue doing smaller items.. like most my clocks that are typically at most 10".. for me.. I'd never buy a large Excalibur due to price.. and I don't care for the blade being so close to the front.. so doing large work and having a large saw throat for me personally.. the EX wouldn't be my choice.. That's why I plan to hang onto my 26" Hawk..
But in doing your research. everyone has a different style of cutting.. and likes and dislikes about a saw.. I'd be nice to have a line up of all the brands at the stores that could be test run.. so keep that in mind when reading reviews..  I have had many entry level saws that while worked good.. but they lacked features and production cutting qualities.. I try not to knock down any brand of saw.. I have 2 Hawks, a DeWalt and a EX-21.. I think if I had to choose one saw.. It'd be a tough call between the Ex and the Hawk.. If the EX had the blade set back a little farther.. it'd probably be my choice.. I can live with the manual lifting arm.. since it stays up on it's own.. unlike the DeWalt (without the easy lift attachment ) ..  I suppose my Hawk would be my choice.. for just one saw.. I find myself starting out in the shop on one of the other saws.. but I end up on the Hawk before the end of the day..
Top feeder . . . most of the time.  It is nice in fretwork to just lift the arm and lower it and the blade right into the next hole.  Leaning over to look under the workpiece and fish the blade up is great for some folks, but I'm too fat/old I guess.  Also, for me at least, it's easy to see the hole against the backdrop of the white pattern.  If I'm looking up from under the project, the holes aren't as obvious, and when I do find it,  I often end up coming up through the wrong hole.
But the advantage of bottom feeding, if you have a blade that fits the hole tightly, the blade doesn't catch going that direction.  The second advantage of bottom feeding, is that you only have to thread one hole.  When you top feed, you also have to be lined up with the hole in the table.
Regardless of what you chose, going to any of these better saws will give you blade change improvements that will seem like a miracle compared to you current Wen.
Edited by hotshot
I've been a been a bottom feeder from the start. I'd like to think I'm a good person, too. I've had a number of different saws, 2 of them being Hawks. My CW - 40 can be used as a top or bottom feeder. It was the first 16" saw I bought new that had that capability. Some will disagree will that, but it can be done.
I've had other saws that were just bottom feeders. My present BM -26 Hawk is a top or bottom feeder. It's a matter of changin' blade clamps. I never succeeded at top feeding, so am a bottom feeder for life. I guess.
Choosing a new saw can be confusing. Look at all the angles, & what suits you. Otherwise it'll just be a boat anchor. jmo.
I'm a devout and unapologetic bottom feeder.  I'll leave it up to others to declare if I'm a good person or not.  :D
My first saw was a Craftsman, bottom feed only, so I learned that way.  When I got my DeWalt and even when I upgraded to my EX, I stayed with bottom feeding, even though they are top feed capable.  I tried it and didn't like it.  I know I didn't give it enough of a chance, but I'm completely comfortable bottom feeding.  It's like the metric system.  I know it's easier, but I have no interest in converting and you would have to pry my Imperial tape measures and rulers out of my cold dead hands.  :lol:
In my estimation, the only negative referral to "bottom feeder", is when referring to attorneys or lawyers. They are true "bottom feeders".
Ray
7 hours ago, ike said:
I am a bottom feeder . For me ist is the easiest way.but I do help myself i use a awl pushed into the hole to make it a lot smoother and easier to see and hit with the blade, I got my awl with a screwdriver set from Sears  ther cost are $5/$10 and in my openion they are well worth it.
IKE
When I took the marquetry class, the instructor gave each of us a small counter sink drill. Hand held and operated. It opens up the mouth of the tiny holes just enough to make it easy to stick a 2/0 blade up through the #68 hole. So far, I have done this on all the stuff that I have cut. But, with that said, I'm now going to give top feeding a try. It may end up being my blade feeding choice.
Ray
5 hours ago, meflick said:
Well, I am left handed. When you are left handed in a right handed world, you learn quickly to adapt and be ambidextrous. ;) As a result, I have found that since my saws allow me to do either, I sometimes feed from the top, and sometimes from the bottom. The bonus is, I can hang out with either group and fit in. ;):lol:
Excellent post. I too am a left handed person but am also semi ambidexterous. I can go either way.
Ray
Amen to the metric/imperial debate. It would have been nice to have learned metric at a young age but I didn't so I'm just like you.
Ray
We are getting a little off the original  purpose of this thread, however, let me add this an then I will but out.   I also counter sink my holes when necessary, I also have a grinder close to my saw and every blade I use, I grind a sharp point in the top end.  Takes but a second and really makes it easier to start the blade up through that hole.
This is a great idea Paul. My problem is, I have a cheap H/F grinder that I hate to turn on. The reason I hate to turn it on is, it will still be spinning for an hour after I turn it off. I would love to have one that has an electric brake on it. Or some electronic device to slow/stop it quickly. It's a great grinder but that one thing keeps me from using it.
Ray
I also started out with a bottom feed only Craftsman.   I then went to a Delta P20 which can be either top or bottom fed but continued to bottom feed most of the time.   I now own a Hegner and have no choice but would like the option especially on large fretwork projects.   I don't think I would buy another scroll saw that didn't have the top or bottom feed option. JMHO
Ray
LMAO - I have that grinder, it's my first and only - I thought all grinders took hours to stop spinning LOL
I like this idea - thanks!
But back in ;)
