3Dface Posted March 17, 2018 Report Posted March 17, 2018 side thread to "Elmers Spray Adhesive By Rockytime" i am doing experiments today for my 3Ds. had a 3M 77 applies cover start to peal up. that is with 5 coats of clear spray matte over it. i am trying 7 different combos of mod-podge 3M 77 and clear coats. i do not have any experience with Varnish. can anyone tell me if it turns white or chips at the edge of a cut? is there any "Hard drying" treatment you would advise? thanks Quote
Dan Posted March 17, 2018 Report Posted March 17, 2018 If you want a deep looking clear finish that is quite durable try Rustoleum Triple Thick Glaze. I've used it on jigsaw puzzles and was happy with the look. For the adhesive, I used Aleen's clear spray glue. It worked for me on the puzzles. Some other puzzle makers used Aleen's bottle glue and spread it on. Ether way seems to work. OCtoolguy and 3Dface 2 Quote
Rockytime Posted March 17, 2018 Report Posted March 17, 2018 This does not answer your question but I have not heard about varnish for many years. But, as a kid I remember my mother varnishing things. I think that's the last time I heard about varnish. OCtoolguy 1 Quote
3Dface Posted March 17, 2018 Author Report Posted March 17, 2018 14 minutes ago, Dan said: If you want a deep looking clear finish that is quite durable try Rustoleum Triple Thick Glaze. I've used it on jigsaw puzzles and was happy with the look. For the adhesive, I used Aleen's clear spray glue. It worked for me on the puzzles. Some other puzzle makers used Aleen's bottle glue and spread it on. Ether way seems to work. did you glue pictures to the face of the puzzles? i think i have the glaze... will have to look and just ordered the spray glue. OCtoolguy 1 Quote
3Dface Posted March 17, 2018 Author Report Posted March 17, 2018 1 hour ago, Rockytime said: This does not answer your question but I have not heard about varnish for many years. But, as a kid I remember my mother varnishing things. I think that's the last time I heard about varnish. i have 3 very old 1gal cans. used some about 3 months ago to seal a table that is about as old. i was very surprised it still worked. my neighbor has a can shaker i put the can in for about 30 min before i used it. OCtoolguy 1 Quote
Dan Posted March 18, 2018 Report Posted March 18, 2018 2 hours ago, 3Dface said: did you glue pictures to the face of the puzzles? i think i have the glaze... will have to look and just ordered the spray glue. Yes I did glue the pictures to the wood then sprayed 2 or 3 coats of the Glaze then cut the puzzles. I always let the glue set for 24 hours. Also lest the Glaze dry 24 hours before cutting. OCtoolguy and 3Dface 2 Quote
kmmcrafts Posted March 18, 2018 Report Posted March 18, 2018 I've done the arleens tacky glue for puzzles and then used the triple thick glaze as Dan mentioned with good results.. But the trick with that glue is getting it on thick and smooth enough.. my first puzzle I got it on too thick and it ended up with some lumps or dips in it where I picked it up before the glue had dried.. so next time I made a fairly thin smooth gluing.. but in sawing it it lifted off the board.. Next puzzle came out better.. but I think a spray glue like for patterns might be a easier better option.. haven't tried that one yet though.. OCtoolguy and 3Dface 2 Quote
Dan Posted March 18, 2018 Report Posted March 18, 2018 4 minutes ago, kmmcrafts said: I've done the arleens tacky glue for puzzles and then used the triple thick glaze as Dan mentioned with good results.. But the trick with that glue is getting it on thick and smooth enough.. my first puzzle I got it on too thick and it ended up with some lumps or dips in it where I picked it up before the glue had dried.. so next time I made a fairly thin smooth gluing.. but in sawing it it lifted off the board.. Next puzzle came out better.. but I think a spray glue like for patterns might be a easier better option.. haven't tried that one yet though.. Yes, I'm glad you mentioned that. I bought a wallpaper seam roller to smooth things out and get the glue to spread evenly. 3Dface, kmmcrafts and OCtoolguy 3 Quote
kmmcrafts Posted March 18, 2018 Report Posted March 18, 2018 5 minutes ago, Dan said: Yes, I'm glad you mentioned that. I bought a wallpaper seam roller to smooth things out and get the glue to spread evenly. That's a good idea... I used a credit card to try to keep it smooth.. did okay with it.. but then I picked it up about 20 min. later and put finger imprints in it.. and I couldn't get them smoothed out.. OCtoolguy and 3Dface 2 Quote
MrsN Posted March 18, 2018 Report Posted March 18, 2018 I think of varnish as something that adds a warm amber tone to wood. I would not use that with your pictures because it would change the colors. As for sticking pictures to wood...I use modge podge and cover with clear rustoleum. OCtoolguy and 3Dface 2 Quote
JTTHECLOCKMAN Posted March 18, 2018 Report Posted March 18, 2018 I do not know what you do so I can not add anything useful. I wish you would include what you are trying to do. Your sign-on name means nothing to me so the 3D stuff is not ringing any bells. Would like to help. In pen turning we put decals and photos on pen tubes all the time and cast and maybe this can carry over into what you are trying. Maybe a photo or two can help too. If not then I assume the help you have gotten does work for you. Good luck. OCtoolguy 1 Quote
3Dface Posted March 18, 2018 Author Report Posted March 18, 2018 7 hours ago, JTTHECLOCKMAN said: I do not know what you do so I can not add anything useful. I wish you would include what you are trying to do. Your sign-on name means nothing to me so the 3D stuff is not ringing any bells. Would like to help. In pen turning we put decals and photos on pen tubes all the time and cast and maybe this can carry over into what you are trying. Maybe a photo or two can help too. If not then I assume the help you have gotten does work for you. Good luck. i am sorry. i had posted pics before but should have included one here. this is the one peeling up. the tiny piece between hulks hand and the gun. OCtoolguy and NC Scroller 1 1 Quote
JTTHECLOCKMAN Posted March 18, 2018 Report Posted March 18, 2018 So what is it that you do?? What are these photos and what kind of paper. Are these paintings or photographs or decal. Need more info. What are you mounting to and how is that substrate prepared?? Sorry but I really have no idea what you do. OCtoolguy 1 Quote
3Dface Posted March 19, 2018 Author Report Posted March 19, 2018 23 hours ago, JTTHECLOCKMAN said: I do not know what you do so I can not add anything useful. I wish you would include what you are trying to do. Your sign-on name means nothing to me so the 3D stuff is not ringing any bells. Would like to help. In pen turning we put decals and photos on pen tubes all the time and cast and maybe this can carry over into what you are trying. Maybe a photo or two can help too. If not then I assume the help you have gotten does work for you. Good luck. i am sorry. i had posted pics before but should have included one here. this is the one peeling up. the tiny piece between hulks hand and the gun. here is the back i scroll portraits mostly. i am also using, posters (Beatles) , photos of friends , comic book covers (hulk) and album covers and i use them as a pattern. each part of the pic is cut out in a way that lets me glue the parts back together in the layers this was in real life. counting the background this one is cut into 9 pieces and in 8 layers. before glued back together in 7 layers that help? OCtoolguy 1 Quote
JTTHECLOCKMAN Posted March 19, 2018 Report Posted March 19, 2018 It is starting to get clearer. Have you been doing this long and have you just started having problems?? Is this something new you are trying or is this something that just started happening. I do not like the idea of gluing photos or anything to wood because wood moves and always will,even if sealed. MDF or even particle board.(which probably would not look good on the edges) something of this nature would be a better substrate in my opinion and it needs to be sealed also before attaching any photos. Looks like you use plywood. If you do not seal the substrate it will absorb the adhesive and starve the joints or in this case layers. When doing veneers in woodworking you always need to balance both sides of the veneers or else they will creep is what it is called. You top coat a veneer and the bottom side moves more that the top thus causing lift and usually air bubbles under it. In pen turning when people use decals on a tube the tube is solid and does not move but being it is cast in clear resin moisture is an enemy so it needs to be sealed and usually some people use modpodge or just clear acrylic polyurethane sprays. Then the can cast. OCtoolguy 1 Quote
3Dface Posted March 20, 2018 Author Report Posted March 20, 2018 On 3/17/2018 at 4:41 PM, Dan said: If you want a deep looking clear finish that is quite durable try Rustoleum Triple Thick Glaze. I've used it on jigsaw puzzles and was happy with the look. For the adhesive, I used Aleen's clear spray glue. It worked for me on the puzzles. Some other puzzle makers used Aleen's bottle glue and spread it on. Ether way seems to work. DAMN! that is some sticky stuff!!!!! dropped one corner and almost did not get it corrected. do you put your 1st coat of glaze on thick to soak into the photo or just light coats? OCtoolguy 1 Quote
3Dface Posted March 21, 2018 Author Report Posted March 21, 2018 On 3/18/2018 at 10:53 PM, JTTHECLOCKMAN said: It is starting to get clearer. Have you been doing this long and have you just started having problems?? Is this something new you are trying or is this something that just started happening. I do not like the idea of gluing photos or anything to wood because wood moves and always will,even if sealed. MDF or even particle board.(which probably would not look good on the edges) something of this nature would be a better substrate in my opinion and it needs to be sealed also before attaching any photos. Looks like you use plywood. If you do not seal the substrate it will absorb the adhesive and starve the joints or in this case layers. When doing veneers in woodworking you always need to balance both sides of the veneers or else they will creep is what it is called. You top coat a veneer and the bottom side moves more that the top thus causing lift and usually air bubbles under it. In pen turning when people use decals on a tube the tube is solid and does not move but being it is cast in clear resin moisture is an enemy so it needs to be sealed and usually some people use modpodge or just clear acrylic polyurethane sprays. Then the can cast. i learn things here every day.... i am glad i found this place... thank you.... OCtoolguy 1 Quote
