4 minutes ago, Rockytime said:
What is pre-stain?
Some companies call it wood conditioner, sanding sealer and the like. It helps seal the more porous woods ( pine for ex. ) to help it blotching when you apply the stain. Makes the stain appear more even over the project. If I remember right, MinWax has some good info on their website, been a good while since I was up there.
Thanks Wayne!
Many times, I will use clear shellac as a first coat and it works as a sealer and dries fast.
I do not care for using some of the words I have seen show up recently and in the second post in this thread.  Just not needed IMHO.
Almost definitely box elder. Try sanding to 120 grit then apply a coat of sanding sealer. It's a clear lacquer that helps seal porous wood. Then sand with 180 and 220 grit. Then apply your rattle can finish. Just follow the directions on the can of sanding sealer.
Pre-stain is different and won't work as well.
First if you sand to at least 220 grit you will close the grain some. I used Bulls eye Zinsser dewaxed shellac sealer if I need to do what you are asking. It dries quickly and any type top coat be applied over it without contamination and adhesion problems.
