danny Posted March 26, 2018 Report Posted March 26, 2018 (edited) Just had to add this post to the topic. I have been using this New set up for controlling the excess dust and let me tell you all something. NO DUST GETS AWAY FROM MY Dust Sucker Tubes. Using a Vac named BAD ASH.... It is about Half the Loudness of my normal Shop Vac. Very tolerable to me. Still able to enjoy my Background Music. I don't know how I have been Scrolling for over a Decade without knowing about this set up. Been using the Square box fan with Filter along with the lil fan blowing across the table for Many, many Years. This set up does work Good, but not all the Dust is contained on that filter. Anyway this just be my 13 cents worth of thoughts. Danny :+} Edited March 26, 2018 by danny Hawk, OCtoolguy, Phantom Scroller and 6 others 9 Quote
Phantom Scroller Posted March 26, 2018 Report Posted March 26, 2018 Great dust sucker Danny . Roly OCtoolguy 1 Quote
Fab4 Posted March 26, 2018 Report Posted March 26, 2018 Hi Danny: I guess being called a "sucker" in this case is a really good thing Well done Fab4 OCtoolguy 1 Quote
danny Posted March 26, 2018 Author Report Posted March 26, 2018 Hey guys. Ya.... Vacuum suction just sounded Original to call it a Sucker. Sucker of that Nasty Saw Dust. Even cutting MDF 1/4" for the past day plus.... you cannot notice a trace of dust on table or below. Yea! :+} Phantom Scroller and OCtoolguy 2 Quote
Rockytime Posted March 26, 2018 Report Posted March 26, 2018 Your system sucks in a good way. It does look good! poupster2, danny and OCtoolguy 2 1 Quote
Rolf Posted March 29, 2018 Report Posted March 29, 2018 (edited) I put this system on my Hawk last July and use a Festool Midi vacuum. Like you said Danny I should have done this years ago. I used a couple of Mag switches to hold it to my Hawk table. I also added a trap to catch the small pieces that I did not want to get sucked up. The only thing I was not happy with was that the upper tube was a pain to move out of my way and then back again as the flex tubes are a bit stiff (as they should be). A few weeks ago I added this coupling using it as a swivel. I snugged it down just enough so I have no leak but still easy to swing out of the way. I drilled and tapped a hole in the ring for a screw to keep setting from changing when I swing the nozzle. The large picture was before I added the trap and swivel. Edited March 29, 2018 by Rolf 3Dface, OCtoolguy and Sam777 1 2 Quote
MrsN Posted March 29, 2018 Report Posted March 29, 2018 1 hour ago, Rolf said: I also added a trap to catch the small pieces that I did not want to get sucked up. Can you tell me more about the trap you added? danny and OCtoolguy 2 Quote
OCtoolguy Posted March 29, 2018 Report Posted March 29, 2018 5 hours ago, Rolf said: I put this system on my Hawk last July and use a Festool Midi vacuum. Like you said Danny I should have done this years ago. I used a couple of Mag switches to hold it to my Hawk table. I also added a trap to catch the small pieces that I did not want to get sucked up. The only thing I was not happy with was that the upper tube was a pain to move out of my way and then back again as the flex tubes are a bit stiff (as they should be). A few weeks ago I added this coupling using it as a swivel. I snugged it down just enough so I have no leak but still easy to swing out of the way. I drilled and tapped a hole in the ring for a screw to keep setting from changing when I swing the nozzle. The large picture was before I added the trap and swivel. Great idea. I was looking for something like that but didn't see the swivel that you found. Ray Quote
Hawk Posted March 29, 2018 Report Posted March 29, 2018 What size PVC are you guys using? Chris Quote
Rolf Posted March 29, 2018 Report Posted March 29, 2018 I used 3/4, just don't glue the all of the joints, I have had stuff get stuck in the elbows. Regarding the trap I used 3" pvc and drilled holes in the sides for the fittings. On a wood lath I turned the bottom plug and the lid. But you could just use the regular endcaps for that size pipe. I put a piece of screen inside to catch the bits. If I had thought about it a bit more I would have made a mini cyclone. You can see all of the stuff that got caught in it. 3Dface 1 Quote
Rolf Posted March 29, 2018 Report Posted March 29, 2018 Ray this is the size that fit the pipe I used https://www.lowes.com/pd/Homewerks-Worldwide-3-4-in-dia-PVC-Sch-40-Union/50160563 Quote
OCtoolguy Posted March 29, 2018 Report Posted March 29, 2018 50 minutes ago, Rolf said: Ray this is the size that fit the pipe I used https://www.lowes.com/pd/Homewerks-Worldwide-3-4-in-dia-PVC-Sch-40-Union/50160563 Thanks. That looks like a good idea and I also like your "trap" to catch the little stuff. Ray Quote
Rockytime Posted March 29, 2018 Report Posted March 29, 2018 Thanks Rolf. I've been needing to tap into my regular DC. I have two Hawks and that would work perfect. Your mounting at the rear of the Hawk is very neat. OCtoolguy and danny 2 Quote
Sycamore67 Posted March 29, 2018 Report Posted March 29, 2018 I think using a dust collector for this application is not the best. A dust collector only has 6-8" of suction while a vacuum has 70-90"of suction and will work much better for the small pipe size and all the elbows and stuff. OCtoolguy 1 Quote
OCtoolguy Posted March 30, 2018 Report Posted March 30, 2018 1 hour ago, Sycamore67 said: I think using a dust collector for this application is not the best. A dust collector only has 6-8" of suction while a vacuum has 70-90"of suction and will work much better for the small pipe size and all the elbows and stuff. I agree. Unless you can pipe it down in size to get some real suction at the pipe ends. Sort of the same as a venturi in a carburetor. Air speeds up as it passes through a smaller opening. Ray Quote
Sycamore67 Posted March 30, 2018 Report Posted March 30, 2018 I am sorry but piping down a dust collector does not really get you much. At most a dust collector gives you 8" or so of suction. Closing the end down only increases the suction by a very small amount and nothing close to a shop vac. I am trying to explain this so people do not get the wrong idea. I am not trying to be argumentative but trying to get others to understand. A shop vac has almost 10 times the suction of a dust collector. I have a very powerful cyclone dust collector for my shop. It is a 5 hp and will suck 1800 cfm. This is actual measured flow and not some wild manufacturer claim. However, for my scroll saw and some other things in my shop, the vac does a better job. The vac I am using for my scroll saw has a suction of around 90" and flow rate about 125 cfm. Just to be clear about suction, the inches refer to how high a water column can be pulled up. One can measure it with a water u-tube manometer. The photo is an example of one with blue dyed water that I used to measure suction of a dust collector. OCtoolguy 1 Quote
Rockytime Posted March 30, 2018 Report Posted March 30, 2018 I think the problem is with the noise of the vacuum cleaner. I cannot stand the noise. My HF DC sits outside my shop so the noise is reduced. There are much quieter vacuums than mine but totally beyond my budget. In addition for me I have no room next to my saw. OCtoolguy and Phantom Scroller 1 1 Quote
Rolf Posted March 30, 2018 Report Posted March 30, 2018 Sycamore you are correct. Just curious how do you connect the manometer to your collector system? so that you don't just suck out the fluid? I have been wanting to use some system to monitor my collector and see how it degrades as the filters load up. I only use my shop vac for shop cleanup, cant stand the noise, I did not add this dust collection to my Hawk until after I bought the Festool Middi , which is pretty much useless for shop cleanup with the small hose. It is meant for connection to sanders etc. The bigger Festool vacs use a 2" hose. Rocky time I used a couple of Mag switches to hold the system to my Hawk. If you are not familiar with them they are a switchable magnet, so no bolts or clamps to hold it in place. OCtoolguy 1 Quote
Rockytime Posted March 30, 2018 Report Posted March 30, 2018 I like your setup. I had not thought of mag switches. That is a great idea. I used to know absolutely everything. Oh, that was when I was 16. Forgotten a lot since then. OCtoolguy 1 Quote
Rockytime Posted March 30, 2018 Report Posted March 30, 2018 I just looked up mag switches on Amazon. Holy Smokes! They are pricey at $32 each. Gonna think this over a bit. OCtoolguy 1 Quote
OCtoolguy Posted March 30, 2018 Report Posted March 30, 2018 49 minutes ago, Rockytime said: I just looked up mag switches on Amazon. Holy Smokes! They are pricey at $32 each. Gonna think this over a bit. That was my first thought too Les. Way to pricey to just leave them on the saw. I do like the idea but maybe when the price comes down a bit. Ray Quote
Rolf Posted March 31, 2018 Report Posted March 31, 2018 Our club has a raffle at our meetings, I won one of the mag switches and bought the second. I used the little guys at only $21. Quote
Scrappile Posted March 31, 2018 Report Posted March 31, 2018 Mine is held on with cheap Harbor Freight "C" clamps. Not as pretty but works good. Quote
Rockytime Posted March 31, 2018 Report Posted March 31, 2018 I'd like to have a couple for my table saw. Unfortunately my saw is a collapsible Kobalt saw from Lowes and has a cast aluminum table. They would work on my Band Saw. I will buy some if my ship comes in before my pier collapses! Quote
