12 minutes ago, dgman said:
All the scroll saw catalog and online stores carry them. Having said that, I don't own a set. If I need to clean something up or reshape, I just go back and clean it up with the blade. Quicker and easier!
I agree. I have pattern files but not for scroll saw projects. I use my cheapie scotch thingie balls. Cheap on ebay.
8 hours ago, Rockytime said:
Horrible Fright has small pattern Swiss files made in China. :D They are cheap but work good for a little clean-up. Ebay is another good source. Genuine Swiss files are expensive and won't do any better.
"Horrible Fright"...!! I like that!!  A lot of their merchandise is very cheap....( to say it nicely!)
For small fret work I use emery board ( nail files).... I buy them at the drugstore and they are inexpensive.  They can be cut to different sizes and shapes to fit into small cuts. They work pretty well on softwoods like birch and pine.
For what you are doing, I've found that finger nail sanding boards work quite well. I frequently trim them narrower when sanding in tight places too. Different brands offer finer and coarser grits, and you get a choice of fine or coarse grit depending on which side you use. I have files, riflers, and burnishers, but for most scroll saw projects I've found that the fingernail sanding boards are what I use most.If you want small files, a Google Search will bring up many sources.
Charley
I do not have many projects that need much fine Sanding after all is done.
If I do need the sanding I always use the sanding boards that are used for finger nails.
I have always said 90% of what I Scroll is cut using a FDUR #1 Blade.
Most of the projects are cut using Baltic Birch.  Very little Fuzzes.  Danny  :+}
