i call enough with the cold for this year.
i can't afford to heat an uninstalled building unless i am working in it. so i thought i would share how i save my paint.
i built these shelves when i didn't use paint often enough to need it in the shop. so i knew i needed to keep warm when i moved it..
the floor and walls are covered with 1/4" Styrofoam and the  divider is a cooler lid that falls 1" from the front cover  to allow for air flow and to keep from over heating the paint.
i use a 25W fluorescent bulb. it's surface holds at a temp you can almost hold in in your hand. a regular bulb would melt the styro.
not having room for swinging doors and the fact 1 door had to be about 7" bigger i made a 2 layer cover for the paint side and just the outer for the other.
this has worked great all winter.
