Rockytime Posted April 25, 2018 Report Posted April 25, 2018 On another post the Windows 10 Snipping tool was mentioned. I have it so what is it good for and how does one use it? Quote
new2woodwrk Posted April 25, 2018 Report Posted April 25, 2018 You can use it to take screen shots, highlight and email parts of a website etc. Some find it of use, I do not since there is a "Print Screen" key on the keyboard. Basically you can do the same thing with Print Screen key and MS paint - works fine for me Quote
Rockytime Posted April 25, 2018 Author Report Posted April 25, 2018 So how is it used? I'm not exactly computer literate. Quote
OCtoolguy Posted April 25, 2018 Report Posted April 25, 2018 Rocky, it's used for capturing a picture or a screen shot. I found one that's even better and easier to use. Check out "Jing". It is an easy install and it lives at the top of my screen whenever the computer is on. All I have to do is hover over it and it gives me a little menu that you click on. Then you have two yellow lines that you put where ever you want a corner to be and drag it to the opposite corner and release it. The it asks you if you want to capture what's in that area. Click on capture, then it asks you if you want to save it. You click on the save icon and it will give it a name (usually the date) and you tell it where to save it to. I usually save everything to my desktop so I can find it again. Really a slick little program. The snip tool works the save but I like this one better. Ray SCROLLSAW703 1 Quote
Rockytime Posted April 25, 2018 Author Report Posted April 25, 2018 Thanks Ray. I see I can make a little red square and capture stuff with it. I'll have to play with it. SCROLLSAW703 and OCtoolguy 1 1 Quote
OCtoolguy Posted April 25, 2018 Report Posted April 25, 2018 1 minute ago, Rockytime said: Thanks Ray. I see I can make a little red square and capture stuff with it. I'll have to play with it. Jing is easier to work with. Quote
Scrappile Posted April 25, 2018 Report Posted April 25, 2018 (edited) A snipping tool is what is used to clean Snipes that you catch Snipe hunting. Edited April 26, 2018 by Scrappile new2woodwrk, OCtoolguy, SCROLLSAW703 and 2 others 5 Quote
jollyred Posted April 26, 2018 Report Posted April 26, 2018 How was the snipe hunt this season, Scrappile? I heard there was a record harvest. SCROLLSAW703 and OCtoolguy 1 1 Quote
Rockytime Posted April 26, 2018 Author Report Posted April 26, 2018 Actually I have never hunted snipes but mud hens and shitepokes, you bet. Not kidding, Google it. OCtoolguy 1 Quote
Rockytime Posted April 26, 2018 Author Report Posted April 26, 2018 3 hours ago, octoolguy said: Jing is easier to work with. Thanks Ray. I just downloaded Jing. Just have to practice with it. Appears amazing. OCtoolguy 1 Quote
crupiea Posted April 26, 2018 Report Posted April 26, 2018 Here is what you can quickly do with it. OCtoolguy 1 Quote
blights69 Posted April 26, 2018 Report Posted April 26, 2018 16 hours ago, Rockytime said: Actually I have never hunted snipes but mud hens and shitepokes, you bet. Not kidding, Google it. Shitepokes ? here in the Uk you would use that to describe an undesirable waste of space lol Great word you can never say it once ya gotta say it twice try it OCtoolguy and SCROLLSAW703 1 1 Quote
Phantom Scroller Posted April 27, 2018 Report Posted April 27, 2018 (edited) I use it all the time to screen capture sections of pictures to make a pattern and cut it. Save it to your desktop to find it. It's a very useful tool. I dragged it to my task bar at the bottom of the screen so it's always there, saves looking for it. Roly Edited April 27, 2018 by Phantom Scroller OCtoolguy and SCROLLSAW703 1 1 Quote
heppnerguy Posted April 29, 2018 Report Posted April 29, 2018 I use the snipping tool often. all you do is click on it. then sometimes you need to click on 'new' and then you place your cursor on one of the outside corners of what you wish to capture and after you have exactly encompassed what you wish to save you click 'save as' and it goes to your photos, unless you tell it save it somewhere else. Nothing difficult to it Dick heppnerguy OCtoolguy 1 Quote
Rockytime Posted April 29, 2018 Author Report Posted April 29, 2018 I downloaded "Jing" which is similar. A recommendation from Ray. Works really well and just sits at the topof my screen. Quote
OCtoolguy Posted April 29, 2018 Report Posted April 29, 2018 19 hours ago, heppnerguy said: I use the snipping tool often. all you do is click on it. then sometimes you need to click on 'new' and then you place your cursor on one of the outside corners of what you wish to capture and after you have exactly encompassed what you wish to save you click 'save as' and it goes to your photos, unless you tell it save it somewhere else. Nothing difficult to it Dick heppnerguy Dick I agree. But, I find that the Jing tool works faster and easier. It loads at startup and is always lurking there in the back ground. It lives up along the top row of tabs and also is available no matter what other program I might be using. Because it's already loaded into memory, it doesn't take any time to work like the Snipit tool does. R SCROLLSAW703 1 Quote
heppnerguy Posted April 30, 2018 Report Posted April 30, 2018 3 hours ago, octoolguy said: Dick I agree. But, I find that the Jing tool works faster and easier. It loads at startup and is always lurking there in the back ground. It lives up along the top row of tabs and also is available no matter what other program I might be using. Because it's already loaded into memory, it doesn't take any time to work like the Snipit tool does. R If I find the snipping tool to start to be a problem, then I might look up your suggested program, but for now, I find it fast, easy and enjoyable so for now, I will stick with it. but thanks for the info Dick heppnerguy OCtoolguy and Phantom Scroller 2 Quote
OCtoolguy Posted May 3, 2018 Report Posted May 3, 2018 On 4/29/2018 at 8:01 PM, heppnerguy said: If I find the snipping tool to start to be a problem, then I might look up your suggested program, but for now, I find it fast, easy and enjoyable so for now, I will stick with it. but thanks for the info Dick heppnerguy Dick, I used the Snip tool that came with Windows 7 and liked it. Then I switched over to Win 10 and it wasn't there. So, I went out and found it and added it to my computer. But somewhere along the line, I was told about Jing. I was curious so I went out and got it too. It is a free tool so I figured what could it possibly cost me but my time. After using it and finding out how user friendly it is, well, now that's all I use. Give it a try. You'll like it. I promise. Quote
