Rockytime Posted April 28, 2018 Report Share Posted April 28, 2018 Am I the only person that does not care for reverse blades? I understand the reason for them. I'm cutting a series of letters from 1/2" oak. Occasionally the piece will buck to high heaven and scare the pee doodlers out of me. I know it happens because I've put the blade in a bind. Still don't like it. Happens when I make too aggressive a turn. I find they work OK for me on softer and thinner woods. SCROLLSAW703 and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
lew Posted April 28, 2018 Report Share Posted April 28, 2018 I like reverse blades.....even with the kickback! They seem to really cut clean and the underside of the wood is very smooth. I used to have to sand the back quite a bit to get rid of the fuzzies! I just make sure that when I start up again to cut i hold the piece firmly to the table. I have been using primarily 1/4 inch Baltic Birch. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
spirithorse Posted April 29, 2018 Report Share Posted April 29, 2018 Hi, Les, A lot of people have mentioned that skip tooth blades are much better for 1/2" material because it leaves more room to clear the kerf of the sawdust. If you are using a lot of reverse blades, I suggest you just slow down your feed rate into the blade. God Bless! Spirithorse OCtoolguy and SCROLLSAW703 1 1 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted April 29, 2018 Report Share Posted April 29, 2018 I like reverse blades myself, but I use the MG blades for the puzzles now OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted April 29, 2018 Author Report Share Posted April 29, 2018 1 hour ago, spirithorse said: Hi, Les, A lot of people have mentioned that skip tooth blades are much better for 1/2" material because it leaves more room to clear the kerf of the sawdust. If you are using a lot of reverse blades, I suggest you just slow down your feed rate into the blade. God Bless! Spirithorse Thanks for the suggestions. OCtoolguy and SCROLLSAW703 1 1 Quote Link to comment Share on other sites More sharing options...
heppnerguy Posted April 29, 2018 Report Share Posted April 29, 2018 I bought some Pegas blades to try as there has been so much hype on them. I found that I did not care for them because they are too aggressive for my liking. However, It I was cutting3/4 inch hardwood, they will be the blade I will use. the teeth are bigger on them then other brands, hence the aggressive character. But as far a reversible blades go, I doubt I will ever buy blades that are not reversible for most of the things I cut. Dick heppnerguy OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted April 29, 2018 Report Share Posted April 29, 2018 Use them all the time. I mentioned this many times here. I use Penguin silver reverse #5 FD blades in just about all my cuttings. I cut mostly red oak maple, walnut and never ever ever ever had a problem with pulling up of wood. I allow the saw to do the cutting and do not push. never in a hurry here. OCtoolguy and stoney 1 1 Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted April 29, 2018 Report Share Posted April 29, 2018 I love um and never noticed the kick back perhaps I hold them tighter than you. Roly OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Sycamore67 Posted April 29, 2018 Report Share Posted April 29, 2018 I prefer the FD UR blades...ultra reverse as they are not as grabby. SCROLLSAW703 and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
Frank Pellow Posted April 29, 2018 Report Share Posted April 29, 2018 I use Flying Dutchman Ultra Reverse and, like Roly, I have never noticed any cutback. Also, like him, I always hold my work tight. SCROLLSAW703 and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
Dan Posted April 29, 2018 Report Share Posted April 29, 2018 Like most folks, I never had an issue with reverse toothed blades. No kickback to note. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Bill WIlson Posted April 29, 2018 Report Share Posted April 29, 2018 I've had reverse tooth blades grab for me from time to time. Mostly, I figure it's because I wasn't holding the piece securely or trying to take a turn to quickly, especially in thicker material. When I'm cutting very sharp inside corners, I like to follow the line into the corner, stop, back out a little, then cut across the waste area to the intersecting line. Then I'll cut into the corner point from the intersecting line, turn around in the newly made opening and proceed to cut along the next line. This allows me to cut a sharp point, without trying to spin so hard in the corner, where grabbing can be a problem. SCROLLSAW703 and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted April 29, 2018 Author Report Share Posted April 29, 2018 2 hours ago, Bill WIlson said: I've had reverse tooth blades grab for me from time to time. Mostly, I figure it's because I wasn't holding the piece securely or trying to take a turn to quickly, especially in thicker material. When I'm cutting very sharp inside corners, I like to follow the line into the corner, stop, back out a little, then cut across the waste area to the intersecting line. Then I'll cut into the corner point from the intersecting line, turn around in the newly made opening and proceed to cut along the next line. This allows me to cut a sharp point, without trying to spin so hard in the corner, where grabbing can be a problem. Hi Bill, I do exactly what you do. Sometimes. Every so often I think I can make this corner, no problem and I bind the blade. I was cutting 1/2" oak with a #7 FD Ultra reverse. Onsofter or thinner woods I do not have a problem. OCtoolguy and SCROLLSAW703 1 1 Quote Link to comment Share on other sites More sharing options...
spirithorse Posted April 29, 2018 Report Share Posted April 29, 2018 Steve Good just happened to answer a question about reverse tooth blades for one of his readers. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted April 30, 2018 Author Report Share Posted April 30, 2018 Thanks for posting. I'm sure that will be welcomed by many. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
heppnerguy Posted April 30, 2018 Report Share Posted April 30, 2018 16 hours ago, Sycamore67 said: I prefer the FD UR blades...ultra reverse as they are not as grabby. I just tried them for the first time a couple of days ago and I think they will be my go to blade for 1/4 BB Ply Dick heppnerguy OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Frank Pellow Posted April 30, 2018 Report Share Posted April 30, 2018 23 hours ago, Bill WIlson said: I've had reverse tooth blades grab for me from time to time. Mostly, I figure it's because I wasn't holding the piece securely or trying to take a turn to quickly, especially in thicker material. When I'm cutting very sharp inside corners, I like to follow the line into the corner, stop, back out a little, then cut across the waste area to the intersecting line. Then I'll cut into the corner point from the intersecting line, turn around in the newly made opening and proceed to cut along the next line. This allows me to cut a sharp point, without trying to spin so hard in the corner, where grabbing can be a problem. That's exactly what I do 9in tight corners. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted April 30, 2018 Author Report Share Posted April 30, 2018 Lotsa good advice here. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Chunkthekid Posted April 30, 2018 Report Share Posted April 30, 2018 Like a lot of the other guys, I am a big fan of the FD UR blades. Once I started using them, I have barely touched any of my regular reverse blades. They seem to have much more control and don't grab as much on the up stroke. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted May 1, 2018 Report Share Posted May 1, 2018 Most (99%) of the time I use a reverse tooth blade.. About the only time I do not use then is in very delicate portrait or very thin wood type works.. I've also found that this will happen to me if i am pushing to much ( trying to go too fast ).. in many cases if this happens to me.. I'll speed up the saw to a faster blades speed and typically makes it easier to saw in these cases... OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
