lrmartinez Posted September 27, 2010 Report Posted September 27, 2010 Hi my name is Luis and I have been scrolling for six months now. I just recently purchased the Dewalt 788. I have used it about five times and although it cuts smooth and is a GREAT improvement over my twelve year old pin blade 16 inch Craftman I think it might need some kind of adjustment.The blade as it goes up and down has a slight side to side movement which makes it difficult when making a curve because it eats up small details. Can anyone help me. Quote
Clayton717 Posted September 27, 2010 Report Posted September 27, 2010 Do you have enough tension on the blade? I don't use this saw but my first guess would be the tension being to loose. Quote
lrmartinez Posted September 27, 2010 Author Report Posted September 27, 2010 Yes, I checked the tension it's cranked all also changed blades just in case. Thank you for your suggestion! Quote
Oges Posted September 27, 2010 Report Posted September 27, 2010 Hi Luis, This page may of be some use to you: http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm Quote
lrmartinez Posted September 28, 2010 Author Report Posted September 28, 2010 Gracias I'll check it out. Quote
lrmartinez Posted September 28, 2010 Author Report Posted September 28, 2010 Brett, I just want to thank you!!! The info you sent was what I needed the blade was not aligned properly just needed to tighten some screws. The blade had a side to side motion. Quote
Oges Posted September 28, 2010 Report Posted September 28, 2010 Brett, I just want to thank you!!! The info you sent was what I needed the blade was not aligned properly just needed to tighten some screws. The blade had a side to side motion. No worries .. happy scrolling Quote
