DWSUDEKUM Posted May 1, 2018 Report Share Posted May 1, 2018 Had a need for a bowl to put medications into when at the table so that they were contained and not in danger of getting wet from spilled liquids so I designed this bowl. It is designed to be tip resistant and stackable. This bowl is a combination of skill sets. One set is making a Carole Rothman type bowl and if you wanted to add initials to it fretwork. The lumber I used was 3/8 inch douglas fir. I set the table to 43.7 ° left side down. I used a #3 UR Flying Dutchman blade. Sealed and finished with Shellac. The pattern for this is in the New Patterns DW frankorona, Lucky2 and 3Dface 3 Quote Link to comment Share on other sites More sharing options...
rjR Posted May 1, 2018 Report Share Posted May 1, 2018 It is a very neat bowl. Must have been tricky on the scrollsaw. Quote Link to comment Share on other sites More sharing options...
DWSUDEKUM Posted May 1, 2018 Author Report Share Posted May 1, 2018 3 hours ago, rjR said: It is a very neat bowl. Must have been tricky on the scroll saw. No not really. It was actually quite easy. One outside cut and 2 inside cuts plus some gluing and sanding. It took about 15 min. to setup and cut out and perhaps another hour or so after the glue dried to sand. DW Quote Link to comment Share on other sites More sharing options...
newfie Posted May 1, 2018 Report Share Posted May 1, 2018 Nice work DW thanks for sharing Quote Link to comment Share on other sites More sharing options...
daveww1 Posted May 1, 2018 Report Share Posted May 1, 2018 awesome job Quote Link to comment Share on other sites More sharing options...
rdatelle Posted May 1, 2018 Report Share Posted May 1, 2018 Looks good. I love the wood. Quote Link to comment Share on other sites More sharing options...
meflick Posted May 1, 2018 Report Share Posted May 1, 2018 That ended up very nice DW and a smart idea. Glad to see the visual of it. Thanks for sharing your picture, your pattern and the how to. Quote Link to comment Share on other sites More sharing options...
heppnerguy Posted May 1, 2018 Report Share Posted May 1, 2018 I thought is was a lathe piece when I first saw it. Looks good and is a useful piece. It can't get much better than this Dick heppnerguy Quote Link to comment Share on other sites More sharing options...
DWSUDEKUM Posted May 1, 2018 Author Report Share Posted May 1, 2018 1 hour ago, heppnerguy said: I thought is was a lathe piece when I first saw it. Looks good and is a useful piece. It can't get much better than this Dick heppnerguy Naw Dick I refuse to go over to the Dark Side. Pretty much anything that can be done on a lathe you can do using other tools Carole Rothman type bowls are very easy to make ( takes some practice though ) and has the ability to essentially do anything the designers skill and imagination can come up with. DW Quote Link to comment Share on other sites More sharing options...
GPscroller Posted May 2, 2018 Report Share Posted May 2, 2018 Really nice job, thanks for the pics. Jeff Quote Link to comment Share on other sites More sharing options...
