bandaideman Posted May 3, 2018 Report Posted May 3, 2018 Any one where to find a c!ear on both side 1 inch thick. I found select pine board at Lowe's and others. All of course 3/4 inch. Customer needs it 1 inch ready to add to end of crib so would like it smooth and redy to go. He is in Indiana where I did work for him before I moved to NC. I finished the name he wants but not the board. I am really to ship the name and see if he can find someone in Indiana for the board. The shipping would be a lot !ess thanks OCtoolguy 1 Quote
Phantom Scroller Posted May 3, 2018 Report Posted May 3, 2018 (edited) I usually go to the cheap shop over here like B & M etc and find pine shelving with the brackets for £4.99 for a 4 ft length and then cut it up and even use the wooden brackets. Roly https://www.bmstores.co.uk/products/lovon-pine-shelf-90cm-316090 Edited May 4, 2018 by Phantom Scroller Scrolling Steve and OCtoolguy 2 Quote
Dan Posted May 3, 2018 Report Posted May 3, 2018 Where in Indiana? There's a lumber yard in Cincinnati that carries a great assortment of hardwoods, softwood, and exotics for reasonable prices. WayneMahler and OCtoolguy 2 Quote
Roberta Moreton Posted May 3, 2018 Report Posted May 3, 2018 Where are you in NC? I might be able to put you in touch with one or two sawers OCtoolguy 1 Quote
bandaideman Posted May 3, 2018 Author Report Posted May 3, 2018 I am in Winston Salem area Roberta, Dan the customer lives in Indianapolis, Roly I would have not thought of that. Thank you all for your great responses. Phantom Scroller and OCtoolguy 1 1 Quote
OCtoolguy Posted May 3, 2018 Report Posted May 3, 2018 Maybe Hobby Lobby or Michael's crafts for a pine shelf like Roly mentioned. R Quote
Roberta Moreton Posted May 4, 2018 Report Posted May 4, 2018 Try this Hart Sawmill Services, IncPortable band sawmill based in Piedmont Triad. Check out website for details http://hartsawmill.com or email dana@hartsawmill.com336-240-0275 You also might look at Northcarolinawoodworker.net OCtoolguy 1 Quote
fredfret Posted May 4, 2018 Report Posted May 4, 2018 1 inch clear pine could be very hard to find as most starts as 1 inch and is planed or sanded to 3/4 by the mills. Fredfret OCtoolguy 1 Quote
Travis Posted May 4, 2018 Report Posted May 4, 2018 Go to Lowes or Home Depot and look for select pine stair treads. I think those are 1" thick. I used one for a cabinet top just recently and worked pretty well. See if that works for you. OCtoolguy and JTTHECLOCKMAN 1 1 Quote
bandaideman Posted May 5, 2018 Author Report Posted May 5, 2018 Thanks for the in put. I was able to contact Dana Hart and he did have pine got a board which I will resaw since it is 2 inches and plain to 1 inch. Very nice gentleman. Quote
NC Scroller Posted May 5, 2018 Report Posted May 5, 2018 In the future you can try gpshardwoods.com as well as hardwoodstore.com Roberta Moreton 1 Quote
bandaideman Posted May 5, 2018 Author Report Posted May 5, 2018 Thanks Scott for other possibilities I will look into those for future concerns Quote
