Just about used up all my blue tape.  Bought a roll of shelf liner from Wally.  Was unable to find a spot to remove the backing.  Turned on my 1 remaining brain cell and put a piece of masking tape on the front & back and used those as "handles".  Worked great.
Is there a better way, or do I need to put some kind of tape on each time?
jerry  Thanks
jerry  Thanks
When I use a piece, I try to bend over the corner of the next piece so I have a way of finding it and also of parting it from the back. What you did is ingenius.
R
2 hours ago, Scrappile said:
Jerry, I think you found the "better way".  I always struggle with removing the backing, and I have some double sided tape that is even worse.
On my double sided tape, I cut the tape shorter that the backing.  That works well.  After I get a ways into the shelf liner, I will try it there also.
Thanks for the Replies Friends !!  :):)
jerry
3 hours ago, Karl S said:
Grab the edge like a tearing motion and only pull slightly until it starts to tear then you can separate the baking from the liner, the paper tears but the liner doesn't
:) jerry
Yesterday I used a piece again.  Went with the idea of Octoolguy.  Bent over a very small corner.  Took the flat side of a pencil, held it firmly down on the crease and ran it across a couple of times.  Because the paper & the liner were 2 different radiuses, they sheared apart.  When the pencil was lifted, two things happened:
1. The sticky shelf liner paper popped back down flat & the paper stayed folded, providing a very nice handle.
2. It put a smile on my face to see how ridiculously easy that was.
Again, the credit goes to Octoolguy.
jerry
22 hours ago, crupiea said:
Good call. Might start using that on my trash bags. I get to the point where I just cant figure them out and just cut a corner to get them open.
On trash bags wet the thumb & forefinger.  They will slide the 2 layers of the plastic, (on top) creating a bubble.
jerry
