orangeman Posted June 1, 2018 Author Report Posted June 1, 2018 3 hours ago, Rockytime said: If there is a wobble to the blade it would seem to me you have a tension problem. Like not enough enough tension. Tension is very very tight. Not a tension problem at all. Blade has a slight wobble whereas the Hawk and Delta have no wobble. Very smooth. bb OCtoolguy 1 Quote
lew Posted June 2, 2018 Report Posted June 2, 2018 If you buy either saw from Home Depot web site , then you can return it to any local Home Depot store. If you buy from Amazon then the return process is much more complicated. OCtoolguy 1 Quote
orangeman Posted June 2, 2018 Author Report Posted June 2, 2018 3 minutes ago, Rolf said: Wobble side to side? Yes, a slight wobble side to side on the Hegner. No wobble on Hawk or Delta or DeWalt. bb OCtoolguy 1 Quote
kmmcrafts Posted June 2, 2018 Report Posted June 2, 2018 Maybe alignment issues? I don't know Hegner saws so I can't say.. but of other saws I always had to adjust the blade tension set screws so the blade goes up & down straight and square.. if If you have a small square.. actually I've used anything flat and a straight edge.. even a credit card once just for a quick check.. but set it next the the blade and run a cycle up and down.. I rotate the motor on the hawk without turning it on.. but you can also set the speed as low as it goes.. watch for a gap in between the straight edge and the blade through the cycle... at a fast speed.. it looks like a wobble.. OCtoolguy 1 Quote
OCtoolguy Posted June 2, 2018 Report Posted June 2, 2018 On the Hegner there is no way to "set" the blade to center on the lower clamp but on the upper clamp, there is a locking knob that centers the blade clamp. Make sure the blades are in the clamps correctly. They should be against one shoulder of the clamp and the lock screw run up to them to clamp the blade in place. I have a Hegner and a Dewalt and I get no "wobble" out of either of them unless I have forgotten to tension the blade. Which happens more often that I like. Quote
kmmcrafts Posted June 2, 2018 Report Posted June 2, 2018 2 hours ago, octoolguy said: On the Hegner there is no way to "set" the blade to center on the lower clamp but on the upper clamp, there is a locking knob that centers the blade clamp. Make sure the blades are in the clamps correctly. They should be against one shoulder of the clamp and the lock screw run up to them to clamp the blade in place. I have a Hegner and a Dewalt and I get no "wobble" out of either of them unless I have forgotten to tension the blade. Which happens more often that I like. So I’m not the only one that forgets to tension the blade huh lol OCtoolguy 1 Quote
jerry1939 Posted June 3, 2018 Report Posted June 3, 2018 I'm supposed to tension the blade? jerry OCtoolguy 1 Quote
