Greetings,
Welcome to the forum, Aris,
A lot of people place pieces of rubber, carpet, or cardboard under the scroll saw and clamp or bolt it to a sturdy scroll saw stand.
You can also put weight such as sand bags on the scroll saw stand itself on bottom cross members of the stand to help reduce vibration.
I hope to see some of your projects when you can show us.
Good luck and God Bless! Spirithorse
The best thing to reduce the vibration on that machine is to have it bolted down solid to the work bench. I had one of these saws and I found it to have a lot of vibration until I bolted it to my work bench and then it instantly had no vibration at all. I hope this helps. Welcome to The Village.. Be sure and check out the pattern library and start with the easier patterns and you will quickly be doing about anything you wish to take on. Glad you decided to join our world wide family here
Dick
heppnerguy
