Rockytime Posted June 14, 2018 Report Posted June 14, 2018 I throw away blades that have been used substantially. But there are times I will switch to a different blade for a few final cuts. I do not want to throw it away so I return it with new blades. Do any of you have a system for used blades? SCROLLSAW703 and lawson56 2 Quote
Scrappile Posted June 14, 2018 Report Posted June 14, 2018 I put them back in the tube with the unused, like you. I know which ones in there have been used because I always grind the top tip of my blades to a point before using them.. OCtoolguy, SCROLLSAW703 and amazingkevin 2 1 Quote
jerry1939 Posted June 15, 2018 Report Posted June 15, 2018 I label the blade # on used plastic water bottles. Put a rubber band around the top & bottom. Put slightly used blade outside the bottle, under the rubber bands. When selecting a blade, I return that bottle upside down into a "spice rack" type holder, as a reminder as to what blade I'm using. jerry OCtoolguy 1 Quote
Rockytime Posted June 15, 2018 Author Report Posted June 15, 2018 Thanks guys for the suggestions. OCtoolguy 1 Quote
jscottj Posted June 15, 2018 Report Posted June 15, 2018 I have a couple small magnets on my flexible light by my saw and place my used blades there for future use. Close and handy OCtoolguy 1 Quote
JTTHECLOCKMAN Posted June 15, 2018 Report Posted June 15, 2018 I use to just throw them out. But recently I started throwing them in a container because I also make pens I tried using the old blades for casting into a pen blank and came up with something like this. Hopefully I will at some time make some more and with different ideas but so many irons in the fire. OCtoolguy, amazingkevin, RabidAlien and 1 other 3 1 Quote
kmmcrafts Posted June 15, 2018 Report Posted June 15, 2018 That's one nice thing about the Hawk scroll saws.. I must have about 10 blade clamps.. I engraved the most popular blade size on the clamp.. This way I can have several styles of used blades already loaded in the clamp. only use a #3 for a few minutes but my next project takes a #5.. no big deal.. take the loaded #3 out and set it on my tool tray.. insert the #5 blade.. next time I need that #3 it's loaded in the clamp in my side tray.. when it gets worn out.. replace it.. I never have to fool around with what to do with those partly used blades.. amazingkevin, Scrappile, SCROLLSAW703 and 1 other 3 1 Quote
CharleyL Posted June 15, 2018 Report Posted June 15, 2018 (edited) I have a magnet on the side of the upper arm of my DeWalt saw. If I'm temporarily switching to another blade for part of a project, the blade not in use is held by this magnet until I need it again. For very tight areas I sometimes switch to a spiral blade, clean out the tight area of the pattern, and then switch back to the first blade with the blade not currently in use being held by the magnet. As a general rule I don't switch blades often, and I replace them frequently when they become dull. They are worth only about $0.20 - 0.30 each in gross quantities and I hate it when a dull blade begins burning the wood or it begins wandering off the pattern line. I would rather trash a partly worn blade than put up with the problems that a dull blade causes. I always begin each cutting session with a new blade, since I usually fail to leave myself a note as to how much use the blade in the saw has seen. Blade costs are one of the smallest expenses. Why waste project quality and your time because you used a dull blade that burned the work or caused a wandering cut. Not every new blade in a bundle is perfect either. If I begin cutting with a new blade and have any problem at all with it, I'll replace it before cutting any further too. Again, they are one of the smallest expenses in the project. Charley Edited June 15, 2018 by CharleyL Joe W., Scrappile, OCtoolguy and 1 other 3 1 Quote
Phantom Scroller Posted June 15, 2018 Report Posted June 15, 2018 (edited) Like Charlie I have a magnet on the arm of the saw and also have one on the side of the table for a old blade to push through holes that are a bit awkward. Roly Edited June 15, 2018 by Phantom Scroller amazingkevin and OCtoolguy 1 1 Quote
Sycamore67 Posted June 15, 2018 Report Posted June 15, 2018 Unless I have only used the blade a very short time, I toss them out. SCROLLSAW703 and OCtoolguy 2 Quote
Rockytime Posted June 15, 2018 Author Report Posted June 15, 2018 14 hours ago, JTTHECLOCKMAN said: I use to just throw them out. But recently I started throwing them in a container because I also make pens I tried using the old blades for casting into a pen blank and came up with something like this. Hopefully I will at some time make some more and with different ideas but so many irons in the fire. John, I should have guessed! Your pens, turnings and cuttings are always exquisite. That is a clever use for blades. Unfortunately I will never get around to casting. That seems to be an altogether hobby in itself. SCROLLSAW703, Phantom Scroller and OCtoolguy 1 2 Quote
Rockytime Posted June 15, 2018 Author Report Posted June 15, 2018 14 hours ago, kmmcrafts said: That's one nice thing about the Hawk scroll saws.. I must have about 10 blade clamps.. I engraved the most popular blade size on the clamp.. This way I can have several styles of used blades already loaded in the clamp. only use a #3 for a few minutes but my next project takes a #5.. no big deal.. take the loaded #3 out and set it on my tool tray.. insert the #5 blade.. next time I need that #3 it's loaded in the clamp in my side tray.. when it gets worn out.. replace it.. I never have to fool around with what to do with those partly used blades.. At $20 apiece I'm gonna have to get busy and make a bunch. One cannot have enough clamps. OCtoolguy, SCROLLSAW703 and amazingkevin 3 Quote
kmmcrafts Posted June 15, 2018 Report Posted June 15, 2018 12 minutes ago, Rockytime said: At $20 apiece I'm gonna have to get busy and make a bunch. One cannot have enough clamps. Yeah, they are not cheap.. I am fortunate that the older Hawk with the barrel clamps came with about 5-6 of them and then I kept breaking blades and thought maybe it was something with the clamps so I bought two more, and found it wasn't nothing to do with the clamps. Then when I bought the newer Hawk.. I was pleasantly surprised when unboxing it that the person who originally ordered the saw had ordered 10 extra clamps.. not sure how many they came with from the factory back in 98... must have been about 5.. as I have 15 of them for that saw, LOL.. amazingkevin, SCROLLSAW703 and OCtoolguy 3 Quote
crupiea Posted June 15, 2018 Report Posted June 15, 2018 I put the old blades right back into the mix with the new ones. They will break on their own eventually so no big deal. I knocked a bunch of blades over the other day which was a pisser. of course they dont just fall straight down, they have to go under every little thing. Still finding them laying around. No idea what size they are. i just sort of bend them a little and can pretty much tell. SCROLLSAW703 and OCtoolguy 2 Quote
RangerJay Posted June 15, 2018 Report Posted June 15, 2018 Once a blade is done I fold and break it in half - then save it to a cup sized container - after that it may find use most often as a delicate glue applicator for fretwork projects that need it - or- sometimes - much less often - as a manual "cleaner" where glue or finishing has interfered with the fretwork - or ..... (really) ..... (but not a lot) ..... (kind of embarassing) - I have found myself using them as a serious toothpick ..... (3/0 is the most effective ......) Jay amazingkevin and OCtoolguy 1 1 Quote
barb.j.enders Posted June 16, 2018 Report Posted June 16, 2018 I have either put it back with the new or I have used painters tape, written the blade description on the tape and taped it to the wall beside my saw. OCtoolguy 1 Quote
JTTHECLOCKMAN Posted June 16, 2018 Report Posted June 16, 2018 If I have a blade that still has life left in it I do as Kevin does, have a bunch of extra clamps and just leave in a clamp and place it in the package the blade came in. I use very limited amount different sized blades so no problem storing them. I always keep blades in package they came in. just nip corner off top and take out blades as need be. SCROLLSAW703 and OCtoolguy 1 1 Quote
amazingkevin Posted June 16, 2018 Report Posted June 16, 2018 I run them to the ground then throw away! Quote
RabidAlien Posted June 17, 2018 Report Posted June 17, 2018 I generally use my blades until they snap on me. I keep one on hand, though, that snapped close to the end, I use it for manual touch-up trims, those little pieces in the middle (usually corners) that didn't quite cut and left a burr sticking out. SCROLLSAW703 1 Quote
wombatie Posted June 17, 2018 Report Posted June 17, 2018 Don't laugh but I have drinking straws in the tubes with the good blades. I make sure the straw is the right size and then I cover the bottom with making tape or painters tape, so that the blade will not fall out the bottom and if I need to keep it I pop in the straw until the next time I need that size blade. Marg Karl S, OCtoolguy, barb.j.enders and 2 others 1 4 Quote
Rob Posted June 17, 2018 Report Posted June 17, 2018 16 hours ago, wombatie said: Don't laugh but I have drinking straws in the tubes with the good blades. I make sure the straw is the right size and then I cover the bottom with making tape or painters tape, so that the blade will not fall out the bottom and if I need to keep it I pop in the straw until the next time I need that size blade. Marg Why would we laugh Marg, that sounds like a great idea! Rob OCtoolguy, wombatie, CharleyL and 1 other 2 2 Quote
OCtoolguy Posted June 18, 2018 Report Posted June 18, 2018 I like that idea Marg, sounds too simple. Why didn't the rest of us think of it? It's off to McD's for some straws. They have the nice fat ones. SCROLLSAW703 1 Quote
Rockytime Posted June 18, 2018 Author Report Posted June 18, 2018 I like the idea also. Since I use the test tube style tubes with caps I think I will try some red coffee stirrers. They can be cut to the length of the blades and will fit in the tube. If I have more than one used blade of the same type,one needs to be tossed. I like all this thinking out of the box. OCtoolguy and SCROLLSAW703 2 Quote
Puzzleguy Posted June 18, 2018 Report Posted June 18, 2018 They can pile up very quickly - I tend to save the fine # 3 blades -sometimes with a very soft piece of wood -the new blades cut too quickly and tear the grain - a worn blade cuts slower and believe it or not typically cuts cleaner ( thou slower -which is probably why their cleaner ) Most sizes like 5-9 are shot when they reach the end of their lives - they get put in a Large folgers can and go to the recycle center when its close to being full-so they dont hurt anybody . OCtoolguy 1 Quote
