Lastchance Posted October 12, 2010 Report Posted October 12, 2010 Which do you perfer in Foot Operated Speed Controls otherwise known as foot pedals, the On / Off ones OR the speed control ones? Thinking about getting one. Does anyone have Pros and Cons for either? Thanks in advance Chance Quote
Brian Posted October 12, 2010 Report Posted October 12, 2010 I would think that a variable speed foot pedal would be difficult to use and cut with. If you have a delicate piece or thin wood and you accidently kick it on to high speed..not good. I find the on off pedal to be extremely handy. My speed control is an easy to reach knob Quote
malc Posted October 12, 2010 Report Posted October 12, 2010 Is there a way of fitting a foot pedel to a machine with a zero volt on/off switch. On mine once the power is removed there is no way to turn it back on without pressing the on switch. I believe this is common on most electrical goods with blades in the UK. Malc Quote
Clayton717 Posted October 12, 2010 Report Posted October 12, 2010 I agree with Brian. I use the on/off pedal and wouldn't be without it. Quote
two saws Posted October 16, 2010 Report Posted October 16, 2010 Chance, I have converted to a foot switch after 5 years and can't beleive I didn't do it sooner!! I would recommend useing the off and on eather the one you keep your foot on to saw and lift your foot to stop, or the one you press down to start,take your foot off and the saw continues to run,than to stop the saw you tap the pedal and it stops. Eather one would be the best to use instead of a varable pedal. Thats works great for a sewing a machine but not for cutting wood!! You run the danger of snapping a blade in a turn on thicker wood and as stated in the reply above ruining a fragile fretwork. One other thing, if you have been scrolling for a few years prepare to break the habit of turning off the saw with the switch thats on the saw!! I am still doing that but it will come around! I also have an old electric clock(the one with a cord attached to plug into an outlet) that I have connected to the pedal to keep track of the time it takes to cut a project. Ervin Quote
