I use a 8" grinder that I have modified by removing the grinding wheels and installing a flex drum sander and a sanding mop.  Been suing it about a year with good results.  Somewhere along the line -  maybe a Youtube vid - I got the idea that by reversing the rotation it would make it easier to use.  Then the sanding would be on the top of the drum and not the bottom.  I thought, maybe less stress on the old back?  It was fairly simple to do, just unbolt the base from the motor and turn it 180.  That way the on/off switch is still to the front.  In operation, it turned out to be a huge mistake.  After having it pull a couple of pieces out of my hand on the drum side and launching a couple off the sanding mop, I have torn the whole thing down and restored it to my original sit up.
Jim
7 minutes ago, oldhudson said:
But experimenting with new methods and materials is the sign of a truly creative person. It worked - it didn't - whatever, you gave it a try. Good show!
Thanks.  I learned about my machine and a little about electric motors in the process too.
