OCtoolguy Posted July 20, 2018 Report Posted July 20, 2018 21 minutes ago, kmmcrafts said: Tip if you’re buying this stuff at your local Walmart. Get it in the hardware section of the store rather than the crafts section as the crafts section is typically smaller cans and higher prices. They didn’t carry the one I typically use so I got the gorilla one. Anyone use this. Note the price difference in the pictures below. Also note, this can of 3M 77 is the one I have had issues with nozzles That's the same can that I have had spatter problems with too Kevin. I've never seen the Gorilla spray before. Quote
kmmcrafts Posted July 20, 2018 Report Posted July 20, 2018 1 hour ago, octoolguy said: That's the same can that I have had spatter problems with too Kevin. I've never seen the Gorilla spray before. Yeah, I've never seen the gorilla spray before either.. not sure if anyone else here might of tried it.. but I figured since they was out of the one I normally use and this was the cheapest stuff they had.. thought I'd give it a try.. I'll post a report once I use it.. just note.. it might be some time because I don't use the spray glues very often. OCtoolguy 1 Quote
