kmmcrafts Posted August 5, 2018 Report Posted August 5, 2018 Any certain brand you use for the Hawks.. I'm not sure where to get it locally as I haven't found anything that says it's dry lube.. until I found this stuff.. I've been using light oil but it's messy and not sure how good it's doing for the saw since it gets sawdust and grime stuck in it etc.. I know I read some of you all use a dry graphite..? https://www.menards.com/main/tools-hardware/automotive/automotive-maintenance/automotive-grease-lubricants/blaster-reg-industrial-graphite-dry-lubricant-5-5-oz/8-gs/p-1498065592810.htm Think this will do? OCtoolguy and SCROLLSAW703 1 1 Quote
JTTHECLOCKMAN Posted August 6, 2018 Report Posted August 6, 2018 I use this on all my tools http://www.amazon.com/Boeshield-Corrosion-Protection-Waterproof-Lubrication/dp/B001447PEK OCtoolguy and kmmcrafts 1 1 Quote
OCtoolguy Posted August 9, 2018 Report Posted August 9, 2018 How about going to a lock shop and buying a small tube of powdered graphite? I used to use that stuff on all mating metal surfaces. It's messy but it works. Better than a spray can. oldhudson, SCROLLSAW703 and kmmcrafts 3 Quote
Scrappile Posted August 9, 2018 Report Posted August 9, 2018 Is graphite powder also okay for bushing and bearings?? I thought that was the responsibility of oils and greases.... I always use graphite powder for like locks. My Hegner says oil on the bushings..... kmmcrafts, SCROLLSAW703 and danny 3 Quote
Rockytime Posted August 9, 2018 Report Posted August 9, 2018 Graphite is messy but does not attract dust. OCtoolguy, SCROLLSAW703 and kmmcrafts 3 Quote
kmmcrafts Posted August 10, 2018 Author Report Posted August 10, 2018 49 minutes ago, Scrappile said: Is graphite powder also okay for bushing and bearings?? I thought that was the responsibility of oils and greases.... I always use graphite powder for like locks. My Hegner says oil on the bushings..... Hawk recommends a light oil for the bearings and bushings as well... but they recommend a dry lube for the front tension release cam area and I think the wedge at the back of the saw.. I've been using just oil.. as that's what the manual says.. however I've seen mention that Hawk now recommends the dry lube.. so I don't know.. I think Brad was one that mentioned he used the dry lube per Hawks recommending it to him.. I thought I'd give it a try and a short test run and check for wear etc.. and see how it goes.. I know the oil collects all the dust and dirt.. etc.. and i don't too much care for that.. and the grimy look that it leaves behind.. after a few hours of cutting OCtoolguy and SCROLLSAW703 2 Quote
OCtoolguy Posted August 10, 2018 Report Posted August 10, 2018 18 hours ago, Scrappile said: Is graphite powder also okay for bushing and bearings?? I thought that was the responsibility of oils and greases.... I always use graphite powder for like locks. My Hegner says oil on the bushings..... Paul, most bushings are what is called "oilite" which I think means that they are pre-lubed and should never need any further lubing. I might be wrong but that is what I have always heard. Quote
SCROLLSAW703 Posted August 11, 2018 Report Posted August 11, 2018 hello KM. yes, it was me. In the manual for the BM 226, it recommends powdered graphite for lube the wedge and for the tension release at the nose of the top arm. I bought mine at Napa. It's just a small tube of dry graphite. It just takes a snort, & you're set. don't try to force a whole boat load in the tension release because it'll just end up on your saw deck. It just takes a small snort, too. OCtoolguy and kmmcrafts 1 1 Quote
OCtoolguy Posted August 11, 2018 Report Posted August 11, 2018 1 hour ago, SCROLLSAW703 said: hello KM. yes, it was me. In the manual for the BM 226, it recommends powdered graphite for lube the wedge and for the tension release at the nose of the top arm. I bought mine at Napa. It's just a small tube of dry graphite. It just takes a snort, & you're set. don't try to force a whole boat load in the tension release because it'll just end up on your saw deck. It just takes a small snort, too. A very small snort. It's messy but it works. SCROLLSAW703 1 Quote
fordamir Posted August 14, 2018 Report Posted August 14, 2018 I have a sakura 21" and use slick 50 dry spray on the two barrels I have. The neat thing about is the act that it has teflon in it and this works its way into the crevices if the metal, Not messy a quite long lasting. OCtoolguy and kmmcrafts 1 1 Quote
kmmcrafts Posted August 14, 2018 Author Report Posted August 14, 2018 This is what I ended up with since I couldn’t find the graphite. Not sure how good it is but I figured if it didn’t work well for the scroll saw I could use it for door hinges etc on the car and bicycle chain etc. So far it seems to be slick and easy working on the saw. But still plan to get the graphite next time I go to the store. I know now that I was looking in the wrong area at the store. So maybe next time I’ll find it. OCtoolguy and SCROLLSAW703 1 1 Quote
fredfret Posted August 14, 2018 Report Posted August 14, 2018 You can find tubes of powered graphite at michaels, Hobby Lobby and any where they sell pinewood derby kits. Scout shops usually have is as it is the only approved lube for pinewood derby's. Pencil "lead" is really graphite in solid form. Fredfret OCtoolguy and kmmcrafts 1 1 Quote
JTTHECLOCKMAN Posted August 14, 2018 Report Posted August 14, 2018 2 hours ago, kmmcrafts said: This is what I ended up with since I couldn’t find the graphite. Not sure how good it is but I figured if it didn’t work well for the scroll saw I could use it for door hinges etc on the car and bicycle chain etc. So far it seems to be slick and easy working on the saw. But still plan to get the graphite next time I go to the store. I know now that I was looking in the wrong area at the store. So maybe next time I’ll find it. This company also makes a great rust loosener. I used it on some tough projects I could not get loose and works better than anything I ever found. SCROLLSAW703 and OCtoolguy 1 1 Quote
BadBob Posted May 19, 2021 Report Posted May 19, 2021 Have you tried DuPont Teflon Lube? I use this on motorcycle chains and other things. Years ago, a locksmith told me never to use graphite in locks. He referred to it as slippery dirt. OCtoolguy 1 Quote
OCtoolguy Posted May 19, 2021 Report Posted May 19, 2021 10 hours ago, BadBob said: Have you tried DuPont Teflon Lube? I use this on motorcycle chains and other things. Years ago, a locksmith told me never to use graphite in locks. He referred to it as slippery dirt. This thread is from 2018. Quote
kmmcrafts Posted May 20, 2021 Author Report Posted May 20, 2021 On 5/19/2021 at 8:46 AM, BadBob said: Have you tried DuPont Teflon Lube? I use this on motorcycle chains and other things. Years ago, a locksmith told me never to use graphite in locks. He referred to it as slippery dirt. Here in the northern states that slippery dirt works really well and is recommended on car locks as it helps to keep moisture out and not having it in there results in a frozen lock that also not only locks others out.. it locks the one with the key out until it warms up above freezing. Not sure about the credibility of that lock smith but he obviously has never worked on many car locks in the north. BTW, I've used the graphite in locks for many years.. one lock I have is 40 years old Master lock.. and has been locked / unlocked etc. pretty much twice a day for all those years.. still working very good. I'm not sure why Hawk recommends it for the saw.. I don't use it on the saw because of the mess it can make.. I find just regular oil works best for me.. many folks ( one used to be a regular on here ) never ever oil their Hawk saw.. and are production cutters. They've never worn anything out other than the tension cam every 6-8 years, LOL. So I assume oil or any lube is better than none at all. OCtoolguy 1 Quote
BadBob Posted May 21, 2021 Report Posted May 21, 2021 18 hours ago, kmmcrafts said: Not sure about the credibility of that lock smith but he obviously has never worked on many car locks in the north. I lived in North Dakota for several years, and I know all about frozen locks, etc. I quickly learned that to use only synthetics, dry lubes, or no lubrication at all if you wanted it to move at -40F. If you used nonsynthetic oils, you had to heat it to keep it moving. We had propane heaters on our diesel engines and electric heaters on the gasoline engines. Gas engines didn't need heaters if they had synthetic oils. I don't know or don't remember why the locksmith said that, but I took it to heart and never used graphite again. I never liked the stuff. kmmcrafts and OCtoolguy 2 Quote
