jbrowning Posted August 9, 2018 Report Posted August 9, 2018 Does the Hawk 226VS use a allen wrench to adjust the lower blade clamp? Mine didn't have one come with it. OCtoolguy 1 Quote
Rockytime Posted August 9, 2018 Report Posted August 9, 2018 Your lower clamp should look like this with exception of the round knob which is not from Hawk. I don't know where one would use an allen wrench. However yours is a 226 and mine is a 220. jbrowning 1 Quote
OCtoolguy Posted August 9, 2018 Report Posted August 9, 2018 Les, is there an anvil on the back side of the blade clamp where the blade gets pushed up against? On my saws, there is an allen screw that is the anvil for the clamp. I can't see well enough on your pics to tell but I think there is. jbrowning 1 Quote
kmmcrafts Posted August 9, 2018 Report Posted August 9, 2018 There is a set screw on the opposite side of the thumb screw on the lower blade holder.. Your clamps are just like what Les posted above.. I just watched your 2nd video you posted the other day.. The lower clamp is there in the lower arm.. your video shows the set screw being in there.. as well as on the upper blade clamp.. That blade clamp comes out.. in order to change blades if you look on the right side of the saw on that brace that runs along side the upper arm.. there is two different sets of holes drilled into that.. You put your holder roll pin into one of those holes and the upper lip on the clamp should lock over the top of that upper brace.. this holds it while you loosen / tighten the thumb screw for changing the blades.. jbrowning 1 Quote
kmmcrafts Posted August 9, 2018 Report Posted August 9, 2018 Okay here is some pictures , not sure you can see the set screw in this clamp opposite of the thumb screw. Then there is the picture of the hole for your blade changes, then I took one with the clamp in the hole for doing a blade change. The other pictures are of the two slots in which you set the blade holder into in the lower arm. The front slot is for a less aggressive cut or for thin wood cutting the one toward the back of the arm is for thick wood cutting or a more aggressive cut. I personally always use the front one and see little to no difference in the aggressive cutting from either slot. I do notice with it in the back slot I don’t get as good of a cut not squared. Not a huge deal other than cutting puzzles for me anyway or stack cutting. jbrowning 1 Quote
jbrowning Posted August 9, 2018 Author Report Posted August 9, 2018 Thanks everyone, I was watching a video on youtube for the Hawk 220, 226 and 216. I think when the allen wrench came into play they were talking about the 216. Quote
Rockytime Posted August 9, 2018 Report Posted August 9, 2018 Good photos Kevin. I do not use the little holes for tightening the clamp. I find it fiddly. I just tighten by hand. jbrowning and kmmcrafts 2 Quote
