jbrowning Posted August 12, 2018 Report Posted August 12, 2018 So I'm sitting here at the race track resting from a busy day of taking pictures and I'm trying to figure out how to attach a light to my Hawk. Has anyone attached a light to the actual table or do you attach it to something close by? Thanks Jim OCtoolguy 1 Quote
fredfret Posted August 12, 2018 Report Posted August 12, 2018 My hawk has a place on the accessory arm for a magnifier lamp. Which model do you have? Fredfret OCtoolguy 1 Quote
JTTHECLOCKMAN Posted August 12, 2018 Report Posted August 12, 2018 I use a fluorescent magnifier light. I remember years ago I only used it for the light well now I can not scroll without it for both. OCtoolguy 1 Quote
kmmcrafts Posted August 12, 2018 Report Posted August 12, 2018 There should be a hole on the accessory arm that runs along the side of the upper arm where the stem of the magnifier lights fit into.. At least that is how I have mine set up.. I didn't need the clamp bracket that came with my light.. I just stuck the stem down into that hole.. OCtoolguy 1 Quote
Sycamore67 Posted August 12, 2018 Report Posted August 12, 2018 I use a circular magnifying light. I do not attach it to the saw as there small vibrations that make using the magnifier difficult. OCtoolguy 1 Quote
jbrowning Posted August 12, 2018 Author Report Posted August 12, 2018 Thanks everyone, I will look at the saw when I home tonight. I have the 226VS ULTRA. Back to the race track. OCtoolguy 1 Quote
Rockytime Posted August 12, 2018 Report Posted August 12, 2018 My lamp has a standard 1/2" stem. Attaches directly to the accessory arm. I prefer mounting off the saw. OCtoolguy 1 Quote
jbrowning Posted August 13, 2018 Author Report Posted August 13, 2018 Thanks everyone, I found that hole. I would have seen that hole on the saw if I had looked at my video I had made. OCtoolguy 1 Quote
