Sparkey Posted August 22, 2018 Report Posted August 22, 2018 My wife wants me to make her some hair clips. This is not the one I made, mine is in the shop bending. The one I made looks just like this out of purple heart. Does anybody have any tips for bending wood? meflick, Scrolling Steve, bobscroll and 3 others 6 Quote
worbler Posted August 22, 2018 Report Posted August 22, 2018 Never bent wood but I understand it requires steam and pressure. Apparently you can make a steam box out of whatever and steam the hell out of it. Take it out and bend it around a shape. Might have to try that one day but have never had the need to. Quote
dgman Posted August 22, 2018 Report Posted August 22, 2018 You need steam in a steam box or very hot water. Then you need a form. Your project won’t need to much of a bend so I think the hot water might work. I have made oval Shaker boxes so I have a soaking tray and forms. I used a couple of butane backpacking stoves for the heat. This might work for you. You don’t want the water to boil. Soak the project in the hot water for five or ten minutes then clamp the project to the form. Let it cool and dry, then sand. Quote
amazingkevin Posted August 22, 2018 Report Posted August 22, 2018 works in progress will help lots, learn quicker I think. Quote
Scrappile Posted August 22, 2018 Report Posted August 22, 2018 I would put it in a pan of very hot water for a little while, after making a forum of the shape you want. Take a piece of 2"x4", cut the shape you need down the middle of it. Put the wet wood you want bent between the two pieces of your 2x4 mold and clamp the mold together. Let it sit a day or so. Least that is how I would try it. I've done some steam bending, lots of info on the internet, youtube, an woodworking articles. It is fun to play around with. Many different ways to do it. Quote
loftyhermes Posted August 22, 2018 Report Posted August 22, 2018 You can bend thin wood with heat. Google bending iron these are used a lot by Luthiers/ guitar makers. Quote
rjR Posted August 23, 2018 Report Posted August 23, 2018 I have bent wood with a wet cloth and a steam iron uing 1-by 2 stock to make a curved railing. It was slow but worked. I am sure the cut 2 pieces and clamping it between them when hot will work. It might take a couple of tries to get it where you want. A little less presure the first time; so bing careful not to crack it. Quote
