Vector01 Posted October 26, 2010 Report Posted October 26, 2010 Anybody bored yet? OK...A note on the blade screws. I noticed when stoning, the machined pins in the blade screws? I figure the logic behind that was once the pin contacted the screw it would not turn, preventing blade twist. Betcha it looked great on the drawing board I went ahead and tried something I did on the Hitachi. I removed the thumb hold down screw and tried it in the blade holder. It worked. A good idea in case you need a blade screw in a pinch. The hold down screw has a much wider contact surface than the pinned blade screw. Hmmm...Very Interesting. Distance between blade holders...I had no issues with this. Plenty of extra blade beyond the blade screws on both upper and lower holders. So far so good Tensioning lever...Another common problem is maxing out the tension on the lever to tension the blade. No problems so far. I get proper tension on the blade at #2 setting. Theres an easy fix if needed by adjusting the tension rod. Upper arm lift...No mechanical issues. Although you need three hands to lift the arm, hold it up and feed the blade into the hole. I came up with a quick fix. Made a simple hold up from scrap oak (see pic). Works great. I don't think I'll even need an "easy lift." Quote
toolbeltman Posted January 17, 2011 Report Posted January 17, 2011 Check this out Airman...the part about the tension lever....it's the same as on the Delta that you have...hope this helps Quote
amazingkevin Posted January 17, 2011 Report Posted January 17, 2011 Art ,Good info again.I enjoy the easy lift as it put's the arm up and out of the way when you loosen the tention and the blade by it'self.Then i thread the project thru the wood pull down on the arm and hold it with my 4 fingers and push the blade in with my thumb of the same hand and tighten the thumb screw with my right hand. makes it very conveinient . Quote
Marshall Posted January 17, 2011 Report Posted January 17, 2011 Hey Kev....your thumb screw looks like it has a soda lid glued to it from here .......this is a new one for me ........ Quote
Hartwood Posted January 17, 2011 Report Posted January 17, 2011 Are there instructions in the owners manual on how to adjust the tension rod???? I must set my dewalt to #5 or #51/2 to get proper tension. And that may explain some problems I had with scrolling a piece of Maple. Quote
amazingkevin Posted January 17, 2011 Report Posted January 17, 2011 hi john ,you'll find all your looking fornow at the bottom of this page when you first come in to this forum .Page three of this talk is the start of dw788 repairs and tips and tricks .Check out all the pages 1 thru 10 to find all you can about problems with the dw788. Hope that helps if not chime in again for more help .we get you going! Quote
Hartwood Posted January 17, 2011 Report Posted January 17, 2011 Thanks Kevin, That will help a lot. Quote
toolbeltman Posted January 18, 2011 Report Posted January 18, 2011 Well spotted there Marshall....Kevin is always thinking of ways to keep the saw running... Quote
qlty Posted January 18, 2011 Report Posted January 18, 2011 A bunge cord from a rafter in my shops works 4 me,adj lenth for arm to just stay up Quote
