kardar2 Posted September 25, 2018 Report Posted September 25, 2018 This pop up in my YouTube feeds it is a couple of years old so chances are you might have already seen it. https://youtu.be/bhvvMcn7eYw OCtoolguy and bobscroll 1 1 Quote
OCtoolguy Posted September 25, 2018 Report Posted September 25, 2018 5 hours ago, kardar2 said: This pop up in my YouTube feeds it is a couple of years old so chances are you might have already seen it. https://youtu.be/bhvvMcn7eYw I need to make one of those clamps. I did some compound cuts over the weekend and found that they are tough to hang onto so this is going to be my next build. Thanks. Quote
don in brooklin on Posted September 25, 2018 Report Posted September 25, 2018 I do a lot of compound cutting and at one time I made a clamp. Lost it somewhere so now I use 2 small clamps around 2 pieces of wood. I did glue sandpaper to 2 sides to hold a little better. Like this better than the clamp as I can change from side to side real quick. OCtoolguy and bobscroll 1 1 Quote
OCtoolguy Posted September 25, 2018 Report Posted September 25, 2018 22 minutes ago, don in brooklin on said: I do a lot of compound cutting and at one time I made a clamp. Lost it somewhere so now I use 2 small clamps around 2 pieces of wood. I did glue sandpaper to 2 sides to hold a little better. Like this better than the clamp as I can change from side to side real quick. I've got a couple of the mini clamps. I wonder how they would work. I'll give them a try. Thanks for the idea. Quote
Bill WIlson Posted September 25, 2018 Report Posted September 25, 2018 The mini Quick clamps work fine. When I make multiples of compound cut pieces (such as Christmas ornaments), I usually lay several out on a stick. I made jigs last year and used wing nuts. I liked them better than the Quick clamps, because they didn't get in my way, as I was turning the blanks in the saw. But either method works well. OCtoolguy 1 Quote
OCtoolguy Posted September 25, 2018 Report Posted September 25, 2018 (edited) I am going to be making a votive candle holder that was in a pattern book that I have. It requires me to cut 8 of the same piece using compound cutting. I'm fairly new to this so I have been practicing on some cheap wood before trying it on the more expensive red cedar. I'm getting better but doing the tall side is a bit harder when having to hold the piece tight to the table and I have been rapped a few times in the knuckles by the saw arm. So, I'm going to make a jig. But I will also try the mini clamps too. Thanks for your help. Edited September 25, 2018 by octoolguy Quote
Sycamore67 Posted September 25, 2018 Report Posted September 25, 2018 (edited) I made a clamp for compound cutting and posted it sometime ago. It was spring loaded and add sand paper on the inside. The springs make certain to keep things held properly even after making a cut. I added a couple of knobs to hold it better. I made a couple of different sizes Edited September 25, 2018 by Sycamore67 stoney and OCtoolguy 1 1 Quote
NC Scroller Posted September 25, 2018 Report Posted September 25, 2018 I have made at least a twenty of the compound jig holders over the years. I give them away at demos. Mine are little different. I never use pine as it it to soft and warps and twist easily. I like a hard wood like maple. Instead of threaded rod I use carriage bolts. 1/4 or 5//16. What ever size I use I still the non permanent piece hole one size bigger to allow easy movement. The final step I take is to glue a piece of sand paper to the inside of the clamps. It makes a big difference. Roberta Moreton 1 Quote
OCtoolguy Posted September 25, 2018 Report Posted September 25, 2018 1 hour ago, Sycamore67 said: I made a clamp for compound cutting and posted it sometime ago. It was spring loaded and add sand paper on the inside. The springs make certain to keep things held properly even after making a cut. I added a couple of knobs to hold it better. I made a couple of different sizes Very nice job. I never gave any thought to the springs. I just went and picked up all the stuff I need to make one like yours. Except the springs. Quote
JustLarry Posted September 26, 2018 Report Posted September 26, 2018 Steve Good has a plan for one of the jigs. Has a slot so you can do various sizes. I made one without the slot. Works great. On Steve's site http://www.stevedgood.com/catalog/index.php search for compound cutting jig. Larry OCtoolguy 1 Quote
