16 hours ago, Rockytime said:
Thanks for the photos. Do you use a clamp when cutting?
No just my hands, never had any problems and using either FDUR5 or Pegas GT5
Edited by scrollerpete
On 9/27/2018 at 1:13 PM, scrollerpete said:
He always wanted to see the wood prior to cutting my 3D bird houses, well here it is.  I used pieces of scrap and glue them together to get the proper dimensions either 1 1/4" or 1 1/2" square, next glue the pattern to the wood, drill 1/8" hole for the perch, 1/2" Forster bit for the entry to the house. Now we move to cutting I start with the face of the bird house and then re tape it together and cut the other side of the pattern. Take it apart and you have the end products.
Perfect! Now i understand,And boy do I have a lot of small pieces of hardwood  Thank you Scrollerpate!!!!!
10 hours ago, Don Recardo said:
A lovely way to use up scrap wood  and an excellent end result
Are the shapes your own design or from a published plan and if the
latter where can I get he plan ?
Don
The patterns are from Diana Thompson, I understand that she might be ill, but you can get her patterns on Pinterest
Pete, ,you gave me a great idea. I never thought of gluing different pieces together to get the size you need. I have a pattern that's pretty wide but I didn't have any wood that size. Now I do I guess. Thanks.
