Macman Posted October 25, 2018 Report Posted October 25, 2018 1: I can turn a tight corner 2: Spiral blades are not so bad 3: Thin ply is much more difficult to cut accurately. 4: Check a pattern before cutting. 5: A blade snapping is scary 6: mdf cuts well but the dust is awful 7: A smaller piece of wood is easier to cut with. 8: Hegner blade clamps are brilliant. Had a wee play this afternoon with a couple of Halloween patterns. Mainly for the curves and points. Used a spiral which snapped half way around. My first snapped blade and the noise made me jump. Fitted a flat and continued on with the witch. I used a thin bit of ply and it was difficult to hold back the blade All in all a good day. meflick, Roberta Moreton, SCROLLSAW703 and 2 others 5 Quote
OCtoolguy Posted October 25, 2018 Report Posted October 25, 2018 Looks like you are doing great. SCROLLSAW703 1 Quote
Rockytime Posted October 25, 2018 Report Posted October 25, 2018 I agree with number three. I was cutting 1/4" BB with a #1 blade and it cut like a house-a-fire. The small blades are very aggressive on thinner woods for me and I find it hard to stay on the line. Mostly I cut 1" pine. Not very pretty but fun to cut. Looks like you are cutting very well. SCROLLSAW703 and OCtoolguy 2 Quote
Bill WIlson Posted October 25, 2018 Report Posted October 25, 2018 1 hour ago, Macman said: 1: I can turn a tight corner Good. Now try cutting a perfect circle. 2: Spiral blades are not so bad Despite what many scrollers may think. 3: Thin ply is much more difficult to cut accurately. Hence the reason most folks stack cut multiple layers. 4: Check a pattern before cutting. Good idea to plan your cuts before making them. 5: A blade snapping is scary Don't worry, you'll get used to it. 6: mdf cuts well but the dust is awful Paints well, stays nice and flat too, but I still don't like to cut it. 7: A smaller piece of wood is easier to cut with. But too small puts the fingernails at risk. 8: Hegner blade clamps are brilliant. Excalibur owner here, so I'll have to take your word for it. Had a wee play this afternoon with a couple of Halloween patterns. Mainly for the curves and points. Used a spiral which snapped half way around. My first snapped blade and the noise made me jump. Fitted a flat and continued on with the witch. I used a thin bit of ply and it was difficult to hold back the blade All in all a good day. Fun, isn't it? SCROLLSAW703 and OCtoolguy 2 Quote
Macman Posted October 25, 2018 Author Report Posted October 25, 2018 Still smiling OCtoolguy and SCROLLSAW703 2 Quote
CharleyL Posted October 25, 2018 Report Posted October 25, 2018 For being new at this, you are doing great. I think I can already see your future.There will be some very nice bigger projects posted soon. We're all here pulling for you so don't hesitate to ask if you have questions about anything. Charley SCROLLSAW703, Macman and OCtoolguy 3 Quote
wombatie Posted October 26, 2018 Report Posted October 26, 2018 9 hours ago, Rockytime said: I agree with number three. I was cutting 1/4" BB with a #1 blade and it cut like a house-a-fire. The small blades are very aggressive on thinner woods for me and I find it hard to stay on the line. Mostly I cut 1" pine. Not very pretty but fun to cut. Looks like you are cutting very well. I cut 2.5mm bamboo ply with a 2/0 reverse tooth blade lots of times, never had a problem. Just takes practice, and more practice. Marg Scrappile and OCtoolguy 2 Quote
amazingkevin Posted October 26, 2018 Report Posted October 26, 2018 Every project you learn something I found. Perfect cuts you did!!! SCROLLSAW703 and OCtoolguy 2 Quote
Sycamore67 Posted October 26, 2018 Report Posted October 26, 2018 I do not have problems with thin wood or plywood. I typically use a #3 FD UR blade but turn the speed way down. You can easily control the cutting by changing the speed. stoney, Scrappile and SCROLLSAW703 3 Quote
