danny Posted October 26, 2018 Report Posted October 26, 2018 What is your color line to cut on? I have Always used a Black line. Read in another Post that cutting on a Red Line is more Relaxing. Pros n Cons Please......................Danny :+} RabidAlien and OCtoolguy 2 Quote
Scrappile Posted October 26, 2018 Report Posted October 26, 2018 Only you can tell what works best for you.... OCtoolguy, Rolf, ben2008 and 1 other 4 Quote
OCtoolguy Posted October 26, 2018 Report Posted October 26, 2018 I like the idea of being able to differentiate between the black blade and the red line. It's easier on MY eyes. Everybody is different though. Rolf, idler123 and danny 3 Quote
kmmcrafts Posted October 27, 2018 Report Posted October 27, 2018 Just paint the blades.. ... then you can still use the black ink from your printer.. I've cut both red and black... and honestly I like the black... That said though.. it really is dependent on what magnifier light I'm using... My newer LED replacement bulbs light up the black line perfectly but makes the red lines awful bright and kinda strains the eyes.. guess I'm just the odd ball and probably use to the black since I've cut black for the last 14 or so years, LOL OCtoolguy 1 Quote
jollyred Posted October 27, 2018 Report Posted October 27, 2018 I cut on the black line, and have the light coming in from the side, so the blade casts a shadow of the blade away from the line. Don't have a problem telling when the blade is wandering away from the line, which happens quite a bit with my cutting. danny, OCtoolguy and JimErn 2 1 Quote
Fab4 Posted October 27, 2018 Report Posted October 27, 2018 Hi Danny: I tend to use a light grey - For me it makes it easier to see and follow the line Was black for years because it was all I knew - Now, I'm a Villager, and there is always someone here that has a better mouse trap (in a good way) But as Paul mentioned, you have to find what works for you Fab4 OCtoolguy and danny 2 Quote
MrsN Posted October 27, 2018 Report Posted October 27, 2018 I'm a black line girl. I have a laser printer and only print in black and white. danny, CharleyL, stoney and 1 other 3 1 Quote
crupiea Posted October 27, 2018 Report Posted October 27, 2018 I just cut the black line. When i started years ago i thought the red line was easier but it was a pain to make everything red. Just relax. you know what needs to be cut, just do what you know and dont over think it. OCtoolguy, danny and Scrappile 3 Quote
JTTHECLOCKMAN Posted October 27, 2018 Report Posted October 27, 2018 I have been cutting black lines forever. Bobscroller makes his patterns in red so I cut his red lines. Did not have any effect either way. What I do find myself doing is sometimes depending on the pattern cutting either on the line or just inside. Give you an example. The welder pattern which I am cutting now that Bobscroller did for me has such thin areas between cuts so I chose to cut inside the lines to widen those areas just abit. I do this at times with lettering too. These are tricks of the hobby as you keep doing this stuff. OCtoolguy, SCROLLSAW703, kmmcrafts and 1 other 3 1 Quote
danny Posted October 27, 2018 Author Report Posted October 27, 2018 Actually I was just wanting to read Others feelings about Their Favorite color to make the Cutting line. And I did get my answer. Majority cut on Black..........................Cool.......................Danny :+} SCROLLSAW703 and OCtoolguy 2 Quote
Foxfold Posted October 27, 2018 Report Posted October 27, 2018 I use a grey fill with red outline, I find it easier to see those pesky tiny blades. But there again my eyesight is no longer 20/20 SCROLLSAW703, danny, OCtoolguy and 2 others 5 Quote
edward Posted October 27, 2018 Report Posted October 27, 2018 I like the black lines better, find the red is harder on the eyes, guess I'am old. SCROLLSAW703 and OCtoolguy 2 Quote
tgiro Posted October 27, 2018 Report Posted October 27, 2018 Just now, danny said: Actually I was just wanting to read Others feelings about Their Favorite color to make the Cutting line. And I did get my answer. Majority cut on Black..........................Cool.......................Danny :+} I always change black lines to red. That way the blade doesn't get lost in the line. danny, OCtoolguy, SCROLLSAW703 and 1 other 4 Quote
Sycamore67 Posted October 27, 2018 Report Posted October 27, 2018 I use a solid black line. The way I position the light is important to seeing the blade and line. Most of the time I do not cut on the line. With Intarsia, I cut one side or the other. If you cut on the line, you will end up with gaps between pieces. SCROLLSAW703, danny and OCtoolguy 2 1 Quote
danny Posted October 27, 2018 Author Report Posted October 27, 2018 Thanks to ALL for your comments. I did Learn a thing or two with your comments. One is the setting of the Light and also where your sitting (yes I sit to scroll) Old Legs just aren't like the used to be. I never learned to use the Magnifier that comes along with the Light. I am still going to Experiment with cutting on a Red Line. Thanks again My Friends..................Danny :+} OCtoolguy and amazingkevin 2 Quote
Rockytime Posted October 27, 2018 Report Posted October 27, 2018 If a pattern needs enlarging I have it done in red. Otherwise I cut on black. I don't know how to use inkscape. OCtoolguy and SCROLLSAW703 1 1 Quote
SCROLLSAW703 Posted October 30, 2018 Report Posted October 30, 2018 howdy. The only red lines I've ever had in a project was in a Gleaner Combine project. The combine was in the wheat field cutting wheat. I had a copy of the pattern in black and red ink both, but when you studied the pattern, HOLY MOSES!!!!!! Every single wheat head out in front of the combine had to be cut. There were over 400 cuts on that project, and most of them were just cut a little bit for a wheat kernel in a head of wheat, and move to the next. I chose to use the red ink pattern because the smaller patterns were easier to locate and drill an entry hole in. I used a spiral blade for the wheat heads, and some of the other parts of the combine. Around the operator and the cab of the combine, places like that. I believe the project is on my fb page if you care to have a look see. sawdust haven - st. francis, ks. I cut that project in oak, shot two coats of clear shellac over it, and then two coats of clear coat. The project took a total of 80 hours to cut and finish. If I had my choice, were I cutting a lot of fine detail, I would rather have the red ink, myself. I don't use a magnifier or a light at the saw, but the red ink in the fine detail helps me locate it and keep track of it better, where black lines have a tendency t run together. Now if I was only smart enough to figure out how to talk my printer into printin' some of my finer detailed patterns in red ink.:(:( Brad. amazingkevin, danny and OCtoolguy 2 1 Quote
BadBob Posted January 28, 2021 Report Posted January 28, 2021 I use black. I have tried red but it wasn't any better for me. I find good lighting is more important than line color. OCtoolguy 1 Quote
Rolf Posted January 28, 2021 Report Posted January 28, 2021 I have gotten used to the black lines, but for me lots of light is the key. OCtoolguy, danny and stoney 2 1 Quote
FrankEV Posted January 28, 2021 Report Posted January 28, 2021 I find RED to be easier to work with. When I can, I rework the pattern in Inkscape a make the cutout area a very light gray and make the outlines a slightly less red color than the bright red and make the line thickness a thin as posssible. I find I have to often cut with the blade edge against the line instead of splitting the line because the cut out areas are so close together in many hole patterns. The thin red line allows me to do this more easily. amazingkevin, OzarkSawdust and OCtoolguy 3 Quote
OzarkSawdust Posted January 28, 2021 Report Posted January 28, 2021 I'm with Frank on this one. It's easier to tell the line from a floater (from diabetes)I have in my eye. It makes a tiny black squiggle and sometimes lines up with the blade. Light gray with a thin red line works best. What I don't like is a total red pattern. FrankEV and OCtoolguy 2 Quote
OCtoolguy Posted January 28, 2021 Report Posted January 28, 2021 On 10/29/2018 at 5:48 PM, SCROLLSAW703 said: howdy. The only red lines I've ever had in a project was in a Gleaner Combine project. The combine was in the wheat field cutting wheat. I had a copy of the pattern in black and red ink both, but when you studied the pattern, HOLY MOSES!!!!!! Every single wheat head out in front of the combine had to be cut. There were over 400 cuts on that project, and most of them were just cut a little bit for a wheat kernel in a head of wheat, and move to the next. I chose to use the red ink pattern because the smaller patterns were easier to locate and drill an entry hole in. I used a spiral blade for the wheat heads, and some of the other parts of the combine. Around the operator and the cab of the combine, places like that. I believe the project is on my fb page if you care to have a look see. sawdust haven - st. francis, ks. I cut that project in oak, shot two coats of clear shellac over it, and then two coats of clear coat. The project took a total of 80 hours to cut and finish. If I had my choice, were I cutting a lot of fine detail, I would rather have the red ink, myself. I don't use a magnifier or a light at the saw, but the red ink in the fine detail helps me locate it and keep track of it better, where black lines have a tendency t run together. Now if I was only smart enough to figure out how to talk my printer into printin' some of my finer detailed patterns in red ink.:(:( Brad. I'd love to see that piece Brad. Quote
stoney Posted January 28, 2021 Report Posted January 28, 2021 I agree with Rolf the most important thing for me is plenty of light. I have an LED light with an articulating arm that I can position practically right on top of the work piece that floods the area so I have no issue seeing the line or the blade. Quote
RabidAlien Posted January 28, 2021 Report Posted January 28, 2021 My laser printer is B&W, the inkjet is color....so....most of my patterns, regardless of how they look on-screen, are B&W. Or shades of grey, if I make a pattern red/pink and still print it on the laser printer cuz its cheaper. I have a magnifying lamp near my saw so it doesn't really matter which one I do, I'm usually able to follow the pattern either way. Quote
