Gotrocks Posted October 27, 2018 Report Posted October 27, 2018 Some time my tremor causes unwanted "ripples" in the cut. Have been trying different ways to hand sand. Now I have taken broken sanding belt and cut into narrow strips. Then cut to length install set tension and sand away, no tremors ;-). See the video demo. IMG_0215.mov Foxfold, John B and OCtoolguy 2 1 Quote
crupiea Posted October 27, 2018 Report Posted October 27, 2018 Honestly you could just sand that by hand in about the same amount of time and probably get better results. OCtoolguy 1 Quote
kmmcrafts Posted October 27, 2018 Report Posted October 27, 2018 (edited) I've done this on some tight inside cuts where hand sanding wouldn't work.. Edited October 27, 2018 by kmmcrafts OCtoolguy 1 Quote
JTTHECLOCKMAN Posted October 27, 2018 Report Posted October 27, 2018 Whatever gets the job done and work arounds are sometimes just as rewarding as finishing the piece. I love making lots of different jigs in my shop as the need arises for some project. It is rewarding. Now I do have alot of jigs laying around that I can not remember what they were for. if I run into the same situation I usually just make another jig. Scrappile, jollyred and OCtoolguy 3 Quote
OCtoolguy Posted October 27, 2018 Report Posted October 27, 2018 2 hours ago, JTTHECLOCKMAN said: Whatever gets the job done and work arounds are sometimes just as rewarding as finishing the piece. I love making lots of different jigs in my shop as the need arises for some project. It is rewarding. Now I do have alot of jigs laying around that I can not remember what they were for. if I run into the same situation I usually just make another jig. I was just thinking about making a circle cutting jig for the scroll saw. I have one for my bandsaw but it's too big and cumbersome for the size I need. I have found that it is VERY difficult to cut a full circle by hand. I get some very strange circles. Quote
JTTHECLOCKMAN Posted October 27, 2018 Report Posted October 27, 2018 1 hour ago, octoolguy said: I was just thinking about making a circle cutting jig for the scroll saw. I have one for my bandsaw but it's too big and cumbersome for the size I need. I have found that it is VERY difficult to cut a full circle by hand. I get some very strange circles. I never did have a problem cutting straight lines or circles. The eyes are starting to fail so have to concentrate more. That is why I like my RBI saw. It does not cut aggressively and will cut true. It is a matter of practice and remember the key rules, let the saw do the cutting. All you are doing is steering. Try to look a little bit ahead so that tells the brain what you will be doing. I am working on a few patterns now that have complete circles and they came out quite well. I would say another 3 weeks and I will have everything done and will post photos before my shows. Made some cool stuff and hopefully will sell. I do not believe a circle cutting jig would ever work on a scrollsaw. OCtoolguy 1 Quote
Sycamore67 Posted October 27, 2018 Report Posted October 27, 2018 I make sanding stick using popsicle sticks or narrow ones. I lay a bunch of the sticks down side by side, spray 3M77 on good sandpaper and put it on the sticks. I cut them apart with a razor knife. Cheap and works good for me. One thing I have found is that there are huge differences in the brands of sand paper. I use a lot from Klingspor and Norton. Cuts cleaner and longer and more expensive...worth it for me. OCtoolguy 1 Quote
Scrappile Posted October 27, 2018 Report Posted October 27, 2018 I have a circle sanding jig for my sanders. It adjust to different diameter circles. I cut the circle on a band or scroll saw then take it to the disc sander to clean it up. But Norris is cutting odd shapes so his method can handle that. OCtoolguy 1 Quote
John B Posted October 28, 2018 Report Posted October 28, 2018 Great idea, I once saw a frame like that of a coping/ fret saw fitted with sand paper. It would be ideal for sanding inside cuts etc. OCtoolguy 1 Quote
John B Posted October 28, 2018 Report Posted October 28, 2018 On 10/27/2018 at 2:15 PM, octoolguy said: I was just thinking about making a circle cutting jig for the scroll saw. I have one for my bandsaw but it's too big and cumbersome for the size I need. I have found that it is VERY difficult to cut a full circle by hand. I get some very strange circles. If you have a disk sander Ray, you can make circle jig for that, the same as the band saw. I had one when I made 3" and bigger wooden wheels. OCtoolguy 1 Quote
OCtoolguy Posted October 28, 2018 Report Posted October 28, 2018 9 hours ago, John B said: If you have a disk sander Ray, you can make circle jig for that, the same as the band saw. I had one when I made 3" and bigger wooden wheels. Thanks, excellent idea. I have both a disk and oscillating spindle sander. I will make one for sure. John B 1 Quote
Tomanydogs Posted October 29, 2018 Report Posted October 29, 2018 Hi Norris, I have also used the scroll saw as you are doing, however the sanding paper ripped very quickly. I also us emery boards, they come in packs with different widths and lengths. Works good to get the burrs off. OCtoolguy 1 Quote
