For what reason Ma'am, might I ask, can you not get your blade "100% straight?" There are several adjustments you can tweek to get it to a perfect 90* with your saw deck. What breed of saw are you using?
You can adjust the allen screws in the blade holders a tiny bit each direction, if you need to. You can loosen the bolts of the top arm and tweek it a little bit. Same with the bottom. Your table is where I would start. Place a small level on your saw deck and see if reads level, regardless of what the number markings show on the scale. Level your table to that level. Then take a small business card and put it against your saw blade, with tension on the blade. Make sure you put the same edge against the blade on all four sides of the blade. If you're off square of that card then, you can tweek your allen screws in the blade holders to adjust for the difference which ever way it needs to go, right or left.
A square blade will cut longer, and run cooler. And not put near the drag on your machine. Try that and see if it works for you. As mentioned, a few pictures would help us help you you tremendously.
Best of luck, Ma'am.
Brad.
This is just to say thanks for your help.  My husband is getting a new scroll saw for me.  I will then use what you told me on that one.  This one has got me into the hobby that I have come to love.  We have a scroll saw which hubby has had to fix or change it to do the hobby and with the results is the blade can't be made strait.  I won't complain as I have found a lovely pass time made friend's I might not meet and have learnt so much from.  What could be bad about that.  In time I will try to sell them to see how people see my work or keep it to show off the friends I have and what the have helped me to learn about a healthy craft.
Thank you Brad
Thank you Brad
It is a wonderful hobby and I too am so happy I found this forum. The folks here are so welcoming and try so hard to help no matter what the problem or how basic the problem may be because they have all been there. Congrats in advance of your new saw. I hope you and your hubby take the time to research before buying. There are really only about 5-6 saws here in the U.S. worth buying if you are really serious. Way too many "hobby, imported" saws on the cheap.
