Popular Post Macman Posted November 3, 2018 Popular Post Report Posted November 3, 2018 Had a go at stacking today. 3 pieces of 3mm plywood held together with gaffa tape. Was chuffed with the middle piece at the end of cutting. Hardly any fuzzies and no breakouts. I used a Pegas #3 spiral and still found it a bit quick. I still have a good bit of sanding where I have made mistakes but I’m beginning to enjoy sitting with bits of sandpaper whilst relaxing in the warm lounge. I’m aiming to split my time between learning flat blades and spirals. Think it makes more sense doing that My new quick realease arrived for the Hegner and it was a joy to use. So much quicker between cuts. You guys really motivate me and I appreciate it. Pattern by Shadylady0447. crupiea, OCtoolguy, WayneMahler and 7 others 9 1 Quote
meflick Posted November 3, 2018 Report Posted November 3, 2018 Nice work. You are doing great. Keep on learning. Thanks for sharing. Macman, OCtoolguy and SCROLLSAW703 3 Quote
Rockytime Posted November 4, 2018 Report Posted November 4, 2018 Very nice! I still have not the courage to use spirals. Perhaps I should try some. SCROLLSAW703, Macman and OCtoolguy 3 Quote
NC Scroller Posted November 4, 2018 Report Posted November 4, 2018 Nice. Using a smaller spiral (#1 or 2/0) would reduce sanding and handle wood that thick. So would a reverse tooth flat blade. OCtoolguy, Scrolling Steve and SCROLLSAW703 2 1 Quote
lawson56 Posted November 4, 2018 Report Posted November 4, 2018 Down Right Beautiful job,I have stacked cut many times,Just can't get use to them spiral blades Macman and OCtoolguy 2 Quote
Tomanydogs Posted November 4, 2018 Report Posted November 4, 2018 Nice job!!! Get yourself a pack of emery boards from the dollar store, different widths they work great for my fuzzies. Irene Macman and OCtoolguy 1 1 Quote
Macman Posted November 4, 2018 Author Report Posted November 4, 2018 1 hour ago, Tomanydogs said: Nice job!!! Get yourself a pack of emery boards from the dollar store, different widths they work great for my fuzzies. Irene Nice tip. I raided the wife’s make up cupboard and found some. Very handy indeed OCtoolguy 1 Quote
Scrolling Steve Posted November 4, 2018 Report Posted November 4, 2018 Very nice work ! OCtoolguy and Macman 2 Quote
OCtoolguy Posted November 4, 2018 Report Posted November 4, 2018 18 hours ago, Rockytime said: Very nice! I still have not the courage to use spirals. Perhaps I should try some. Les, I have to agree. I have some but haven't tried them yet. I was wondering, when using the spiral blades, do you not have to turn the wood? Is that the idea? Just feed the wood into the blade from all angles and not have to steer it? So to speak. Quote
Rockytime Posted November 4, 2018 Report Posted November 4, 2018 That is my question also. OCtoolguy 1 Quote
Jim McDonald Posted November 5, 2018 Report Posted November 5, 2018 With spirals, you move the wood into the blade following the lines without having to make turns with the stock. Excellent for longer pieces that are too long for the throat of the saw. That said, corners are not as crisp, nor are the cuts compared to flats. I used spirals for a while, but my DW788 with the Pegas clamps does not do well with spirals. I need to make some adjustments to my clamps which will be after I finish ornaments. Quote
Tomanydogs Posted November 5, 2018 Report Posted November 5, 2018 (edited) Made with spiral blade. Steve Good pattern Irene Edited November 5, 2018 by Tomanydogs bobscroll 1 Quote
Scrappile Posted November 5, 2018 Report Posted November 5, 2018 Very nice cutting. I use spiral blades when I feel they are appropriate. When I do use them I use the Flying Dutchman 3/0 New Spiral blade, most. My second favorite one is the 2/0 Pegas spiral. Both are small blades. I use them when a board is too long to turn on my saw. When I can, I turn the board in the direction I am cutting just as I do with a flat blade. I have better control that way. In the places the board can't be turned I than cut with all directions with the blade. I also use the spiral in very delicate work because I can use it sorta like a file and carefully cut/file wood away. They are also very good for "veining" because they make a little wider kerf than a flat blade. To me they are another tool. They have their place and it is well worth it to me, to be able to use them. Takes a little practice, is all. Quote
Bill WIlson Posted November 5, 2018 Report Posted November 5, 2018 7 minutes ago, Scrappile said: Very nice cutting. I use spiral blades when I feel they are appropriate. When I do use them I use the Flying Dutchman 3/0 New Spiral blade, most. My second favorite one is the 2/0 Pegas spiral. Both are small blades. I use them when a board is too long to turn on my saw. When I can, I turn the board in the direction I am cutting just as I do with a flat blade. I have better control that way. In the places the board can't be turned I than cut with all directions with the blade. I also use the spiral in very delicate work because I can use it sorta like a file and carefully cut/file wood away. They are also very good for "veining" because they make a little wider kerf than a flat blade. To me they are another tool. They have their place and it is well worth it to me, to be able to use them. Takes a little practice, is all. +1 Pretty much my sentiments, exactly. I typically use FD 2/0 & 3/0 New Spirals. The 3/0 are really small and fragile, but are ideal for very fine detail. I also turn the board, selectively. It's always more natural to cut when feeding the board directly into the blade, so on critical cuts, I try to spin the board so that I'm pushing from the front, if possible. I generally try to avoid cutting while pulling the board directly towards me. I feel this is the most difficult to control and on some blade clamps, the most likely to make the blade pop out. These aren't hard & fast rules. I'll cut in any direction, if the pattern warrants it. I just try to be selective and make use of the best combination of the blade's capabilities, the pattern's requirements and my comfort level. Jim McDonald and Scrappile 1 1 Quote
