There's a couple things you could do:
First, I'd take out the screw that clamps your blade. Sometimes during the manufacturing process, there is a little nib on the end of the screw. This nib will prevent the full surface area of the screw bottom to come in contact with the blade. If you see a nib, you can take a fine file or some sandpaper and smooth that out.
Second, when they ship scroll saw blades, they'll coat them with a bit of oil to prevent rust. Take a some sandpaper and fold it over. Then slip the end of your blade between the sandpaper and give it a few scuffs (pinch the sandpaper and pull out the blade). This will remove some of that oil and rough up the end a bit so the clamping screw has something to bite onto.
Hope this helps.
Hi malc.lot's of us make the mistake of tightening the blade holder but forget to tighten the blade tention to guitar string tight before turning on the machine.I still do it as my mind is to just keep scrolling ,never mind the details.Maybe this could be the cause of the problem your haveing.If the tention is not up to snuff it will hammar it'self right out of the holder. :)
  • 2 weeks later...
What saw are you using? Had that problem with my previous saw. Had to replace it. Parts not available.
You can't get parts to fix the tensioner on the Craftsman 18". It's a good saw except for that, BUT, it's my backup now as I finally got my DW788. :D
