When I finish polyurethaning and the projects dry I have been getting something like a white fungas. Does anyone know what I'm doing wrong? It doesn't happen to everything only the one's some one wants. :?:confused: Thanks.
Humm I don't know if dipping a mushroom in poly would prevent this or not. A friend brought some stuff over that they finish basketball courts with that he had left over. I think dipping the mushroom in that might preserve the mushroom. When the mushroom dries I'll set it on the shelves I use to dry things on.
I'll try putting somethings to dry on top of a fridge, it's hot and there should be a lot less humidity.
Thanks all. :):)
what do you clean your brush with
Maybe due to the shop temp. The can should be at least room temp 72. or better. When I go out to my shop and turn on the heat, I place my spray cans in front of the heater to warm them up. ( NOT TOO CLOSE, NOT TOO HOT) Just warm them up before you start using them. It might do the trick. I think the colder temps might separate the ingredients. But then again I might be wrong, worth a try.
Are you stiring your stain and clear finishes?
I notice a lot of white fog looking stuff at the bottom and sides of my cans when I do not use them for a while. (cheap home depot type stuff)
I do 007 in reverse. Stired not shaken using a wood stick. I stir slowly for several minutes before I begin. if its a big project I stir often as I move through the project.
Seems to cure that smoke challange when it hardens.
Just my 2 cents
Chance
