I have limited knowledge with bandsaws since I've only had mine a couple years and I just don't use it as I thought I would..  I tried doing some stuff like this with mine and the edges of the wood come out much rougher than that of the scroll saw.. I think a couple of those sharp curves you have would be kinda tight even with the smaller blades.. I was able to achieve my project with the bandsaw but that said.. not really sure it saved me any time because I had plenty of sanding and shaping to do.. and in the end.. I think it actually took slightly longer to do it...
What you need is a CNC to cut the backer while you cut the fretwork, LOL..
While the actual cutting time might be shorter with a bandsaw, I think the resulting cut would require far more clean-up than if it were cut on a scroll saw.  You can put a pretty small, fine tooth blade on a bandsaw, which may minimize the tearout, but I still think the edge will be rougher than using a scroll saw and would require sanding.
If  you have a bandsaw, give it a try, if not on a finished piece, then on some scrap.
If you were really doing high volume, production work and needed good consistency, I would suggest roughing them out on a bandsaw, then cleaning them up with a router and a template.  Probably wouldn't be faster, but might yield the best results.
I'm sort of confused. Aren't we all here because of our love for scrolling? What difference does it make if it takes a bit of time when that is the whole idea behind our hobby? I can understand it if you are in a high volume situation but this is supposed to be a hobby and a hobby is a "pass time". Relax, slow down, enjoy yourself. I enjoy the sawing much more than the sanding and finishing. Partly because of my ignorance on finishes.
