rjweb Posted December 3, 2018 Report Posted December 3, 2018 Good evening, i am Trying to cutting some 3D ornaments, but I was using a fd ultra reverse #5, but it just wants to jump up and down, I am using 1 1/2 inch poplar, any suggestions for blade type and size and what wood I should be using, thx in advance, RJ OCtoolguy 1 Quote
OCtoolguy Posted December 3, 2018 Report Posted December 3, 2018 (edited) I just cut some mahogany in 3/4 x 1 1/2 and I used Pegas #5 mgt. I love these blades. They seem to be good for most anything so far. But, I'm a newbie so take it for what it's worth. I had to cut 8 of the same thing in compound 3-D cuts. Here is what I was cutting. Edited December 3, 2018 by octoolguy lawson56, SCROLLSAW703 and RabidAlien 3 Quote
fredfret Posted December 3, 2018 Report Posted December 3, 2018 Any blade with reverse teeth will tend to lift the work. For 3d you do n I think need the reverse teeth as the bottom of the work is not finish side. I use fd 5 non reverse. OCtoolguy and SCROLLSAW703 2 Quote
Paladin Posted December 3, 2018 Report Posted December 3, 2018 My go to for thick cutting like that would be the FD Polar #5. OCtoolguy, SCROLLSAW703 and New Guy 3 Quote
Sycamore67 Posted December 3, 2018 Report Posted December 3, 2018 I use FD Polar #5 or #7. SCROLLSAW703 and OCtoolguy 2 Quote
rjweb Posted December 3, 2018 Author Report Posted December 3, 2018 Thx for all your suggestions I will give the fd polar a try, RJ OCtoolguy 1 Quote
bandaideman Posted December 3, 2018 Report Posted December 3, 2018 I use Polar on thicker but some 3D is thinner like bird houses or the birds to go on them I use a # 5 reverse. The other thing I found that helps is a jig to hold the project in place while you cut . I do not have capability to show Pics but sure someone else will know what I am talking about and can show you or you may have made one yourself. OCtoolguy 1 Quote
Jim McDonald Posted December 3, 2018 Report Posted December 3, 2018 I cut some birdhouses using FD5UR and the only problems I had were self inflicted by pushing too hard on some of the finer details. Cut those from 1.5" poplar. Sometimes it is getting a feeling for THAT piece of wood and how the stars are aligned above your saw. OCtoolguy 1 Quote
NC Scroller Posted December 4, 2018 Report Posted December 4, 2018 While everyone will have an opinion on this reverse tooth blades are not designed for compound cutting. To cut best you want a blade that removes as much sawdust as possible. That is a skip tooth design like the FD Polar. The reverse tooth design pushes sawdust back in the cut on the up cut. OCtoolguy and Rolf 1 1 Quote
meflick Posted December 4, 2018 Report Posted December 4, 2018 (edited) Ok, first - let's clarify on what you mean by "3-D" ornaments - are you talking about compound cut ornaments? I think so, but just want to make sure. If so, there were a couple of threads over the past year or so discussing and giving lots of good tips and information on cutting Compound ornaments. If so, one of the big tips provided that I "missed" until I tried to cut my first ones is to "NOT use reverse tooth blades" but to use skip tooth blades. The polar blades are skip tooth blades. Here is the thread with most of the good help and tips from several members here, in particular CharleyL, Bill Wilson, and dgman. Charley gave detailed information with photos as I recall. http://www.scrollsawvillage.com/forums/topic/24171-compound-cutting-wood/ It is well worth a read through for anyone who is just learning to cut compound cuts for sure. Then in this thread, I showed my first compound cuts and asked why use skip tooth and not the reverse blades, and Bill Wilson gives a great explanation (which is why I am sharing link to that thread - not to show my work again http://www.scrollsawvillage.com/forums/topic/27019-first-try-compound-cutting/?tab=comments#comment-298429 If you haven't found it yet, Steve Good has a 3-d or Compound Cut Birdhouse pattern - it is the first one I tried and show in that thread above. I tried it because I thought it looked simple enough for me to try. http://scrollsawworkshop.blogspot.com/2017/12/compound-cut-bird-house-and-stand.html This same post on Steve's blog also has a link to his DIY clamp to help holding it while cutting out compound cuts as referenced by @bandaideman above Edited December 4, 2018 by meflick OCtoolguy, JTTHECLOCKMAN, stoney and 2 others 5 Quote
Rolf Posted December 4, 2018 Report Posted December 4, 2018 Like Scott and Melanie said no reverse teeth. OCtoolguy 1 Quote
rjweb Posted December 4, 2018 Author Report Posted December 4, 2018 Thx for all the help, this site is the most helpful with knowledgeable people, RJ meflick and OCtoolguy 2 Quote
