I have been using my new to me saw for a couple of days and I have a couple of issues with it. Intermittently it sounds like the bottom clamp is hitting the blade guard but it is not.  It doesn't usually start doing it while it has been running.......starts as soon as I push the foot pedal. Sometimes it quits in a few seconds, sometimes it continues. Sounds like it is happening at the top of the stroke. Everything in the front  seems tight and no play. My bottom clamp is also bending my blades like a hockey stick when I tighten it. I have taken the bottom thumb screw out and lubed the tip.  Any ideas would be appreciated.
The hockey stick is caused when the set screw and the thumb screw don’t meet in the center of your blade clamp. Because it is the bottom clamp, I usually sit on the floor so I can see. Back out the thumb screw and see where the set screw is, then just adjusting until centered. The only hard part about this is getting back up off the floor.
Can’t help with the noise.
Edited by Roberta Moreton
The hockey stick is due to the lower clamp adjustment. The knocking noise, could be a worn bearing. Had that issue when mine was under warranty and Ray got me straighten out.  Take the blade out and gently move the arms to detect any play if you find any you probably found the issue. Really hard to describe, but a call to Ray at Seyco will be very helpful. Do you have the manual for it Dave ? It will be helpful also. If you need the manual I have electronic copies I can send you.
Dave, long time lurker here.  Not sure if this will help, but I had the same problem.  On the back of the saw there is a nut that holds the tilt mechanisim from slipping.  Mine had come loose and was causing the tilt mechanism to ever so slightly  move.  You can tell by grabbing the tilt wheel and trying to turn it when in another setting besides zero.  The table should not move.
Ed
Have one thanks
The "hockey stick" end can also be the tip of the wing nut not rotating.  It should move fairly easily.  Started having that problem on my QuickClamp on my Hegner just yeaterday.  I took the knurled knob out, clean the tip and put a drop of 3in1 oil on it.  Wiped it good and replaced it.  Fixed the problem.  The knocking problem,, I would call Ray at Seyco.  I bet even the lady that answers the phone could help if Ray is not around.  Could check YouTube also, lots of info out there.  But, a call to Ray would be quicker and probably a lot less trial and error...
That dumb guard rattled on mine too.. and I moved it this way and that and it would stop for a bit but then must have vibrated back or something... The last time I moved it it hasn't rattled since.. because I move it far away from the saw and in a box of parts that'll go with the saw if I should decide to sell it one day, LOL
Talked to Ray this morning. He didn't think it was a metal sound. He said there was a bellows in the bottom tube that had no purpose that maybe that was it. This is the first piece of used equipment I have ever bought. Kicking myself now.
Come on now Dave. You bought a "used car" and there are little things that might not be like a new one. Take your time and once it's all ironed out, you will be very happy. Sort of like kids. You gotta work with them to make them what you want. Sorta.
Paid $625 for it......It wasn't a bargain.  I would rather be making something than tinkering with a saw.  I think I have only bought three used vehicles in my life.
Hey, I feel your pain. I guess I'm different. I would feel cheated if there wasn't something for me to fix. I like doing that. It also helps me to understand just how the saw works. What makes it tick so to speak.. I hope this all works out for you Dave. I know you are frustrated at the moment but you'll be happy in time. Take a breath. Or a shot of tequila. Whatever.
New saws have there unexpected problems as well. I worked on my New Seyco when I got it for several days going back and forth with Ray at Seyco. Finally got it ironed out and am very happy. Would have much rather spent those days making sawdust but it all worked out. I hope you get your issues fixed quickly and back to scrolling. Ray should be able to help you get it going in no time. My EX21 was knocking and it was the motor cam. I had to replace the motor cam and all the linkage. I believe this is a rare occurrence though. You can take the plate off the left rear side with the three screws in it and make sure nothing is hitting and that the motor cam is tight. Good Luck
grizz
Oregon
grizz
Oregon
I am returning it to the guy that sold it to me on Sunday and get a refund.  I will let him deal with the issues. I told him if he gets it fixed I will go ahead and buy it.
I'm curious. Is he going to meet you half way again or do you have to go all the way to Waco?
