UncleApple Posted December 11, 2018 Report Posted December 11, 2018 The good news is that I've been commissioned to created a welcome sign for someone. The bad news is that they want it as an outdoor sign on 3/4 inch thick Curly Maple. I've done 1 outdoor sign in the past (for myself) and it faded horribly within the first 6 months. Can someone please let me know what finish or sealant or combo I should use to make sure this sign looks amazing but is protected and retains its Curly Maple glory?? All help is appreciated as always! Quote
Phantom Scroller Posted December 11, 2018 Report Posted December 11, 2018 I'll be honest I don't think I know of a treatment that will stop it fading etc so I'll follow this with intrepidation . Roly Scrolling Steve 1 Quote
CharleyL Posted December 11, 2018 Report Posted December 11, 2018 A good marine quality Poly will protect it for quite a while, but if your stain isn't Sun resistant it will likely fade anyway. You will need to give the sign several coats and then re-coat it every few years. Sun and Weather are very hard on wood and wood finishes. Stick with a good brand marine grade poly and give it a fresh coat frequently and it should last. Wooden boats last years if the right marine poly is used and maintained. The old sailing ships were given coats of boiled linseed oil frequently to preserve them. If the finish wasn't repeated at least annually, the wood was quickly destroyed. Marine grade Poly smells much better, dries harder, and has UV protection ingredients. It's the more modern finish for the wooden parts of boats. Charley UncleApple and Phantom Scroller 1 1 Quote
WayneMahler Posted December 11, 2018 Report Posted December 11, 2018 For outside finishes I use Spar Urethane. Works well and helps prevent uv fading. Hope this helps. UncleApple 1 Quote
Bill WIlson Posted December 11, 2018 Report Posted December 11, 2018 One alternative for a clear, outdoor finish is clear paint base. If you go to a paint store and ask for a can of clear paint base for an oil based paint, you will get a product that serves very well as a clear, outdoor finish. Full disclosure, I've never used it personally, but the method has been an internet staple for many years. I've never heard of anyone being dissatisfied with it. I have no idea how it might affect the figure in curly Maple, but being oil based, I would think it would accentuate it fine, but again, I've never tried it. As with all new finishing products/techniques, practice on scrap first. This is a cut & paste of the original woodworking forum post from a long time ago. My apologies, as it is quite lengthy. Clear Paint base as an exterior finish "The idea came from a guy in Florida. It was tested in Texas my a well known finishing person(Jim Kull). "As a preface, allow me to set the stage. Almost daily there is a posting about clear, exterior finishes for doors, chairs, signs and such. Responses run the gamut from diehard marine finishes to apply a coat of primer and then paint. Each of these has a bit of a problem. Marine finishes are not always the easiest to find and it grieves me to think of a lovely oak, teak, mahogany, fir, redwood or similar nice wood door painted in mauve goop. Bob from Fl inspired me with his continuing and accurate statements about the failings of a clear coat and the advantages of a good quality exterior paint. I decided after lots of reflection that he really was right but there was always the picture of mauve in my mind. Sooooooooo, how could one take advantage of his advice and yet capitalize on the beauty of a nice wood. I began to reflect on the characteristics of paint. Now, comes the boredom. There were several things I knew about paint. Exterior paints contain a mildewcide and a fungicide that a varnish does not. The best quality paints will contain a UV protectorant and trans-oxide pigments in very high percentages. Almost all paint is custom mixed by the store. The retailer maintains a large supply of base products that are used to achieve the desired color. There are generally 4 base products and the specific one for your paint is determined by your color choice. These base products are either named or numbered. They are named pastel, deep, tint and neutral. If numbered it is cleverly 1, 2, 3 and 4 with the exception of Olympic who numbers 1, 2, 3 and 5. Olympic is unaware that 4 comes before 5. Pastel and/or 1 is virtually a pure white and used for the lightest of colors. The others are slightly color altered from white and more translucent than pastel. These are used for succeedingly deeper colors. All of this comes to neutral, 4 and/or 5. These are clear and used for the darkest colors. In the can they are somewhat opaque but dry more or less clear. Now comes the testing. I bought 4 oak exterior doors. Each door was given one coat of the same MinWax Stain. On 3 of the doors, I applied 2 coats of "paint" to the 6 sides of each door (3 coats on the top and bottom edges). Each of these three doors had a different type of exterior neutral, 4 or 5 base. The fourth door was finished with a common spar varnish from my local friendly paint/hardware store. The bases for the 3 painted doors were an exterior semi-gloss acrylic, an exterior semi-gloss oilbased polyurethane floor paint and a semi-gloss oilbased trim and siding paint. The doors were set up, slightly inclined, in mostly direct sunlight under a pecan tree in the backyard. My wife just loved that one. Daily, the sprinklers managed to hit the doors. The birds in the pecan tree used the doors for target practice. And, yes Steve, the dogs did anoint the doors on a regular basis. My blonde Cocker, Zazu, was particularly enamored with thedoors. Over the course of the test the doors experienced lots of Texas sunlight, rain and snow. The temperature went from below freezing to over 100. The advantage to the inclined position of the doors was the snow, ice, water from the sprinklers and the rain tended to collect in the raised panel areas. I feel these doors were subjected to far more severe environmental conditions than would be expected from normal use. The results were interesting. The spar varnish looked fabulous but after about 2 weeks it began to develop small cracks. In rapid order the door began to turn black, started to mold and the smell was enough to knock a buzzard off of a manure wagon. The waterbased acrylic is milky in the can like a waterbased poly. It dried to a more or less water clear surface but was a bit cloudy. It tended to wash out the stain a bit. Over time it became cloudier and ultimately become almost white. But, it remained solid and protected the wood. The oilbased bases are also a bit opaque in the can but dried to a clear finish that is almost identical to a spar varnish - they added an amber tone to the doors. Both the poly floor paint and the trim and siding paint remained "clear" over the entire test period. The testing came to an end with a bit of encouragement. My wife said something clever like, "Get those damned doors out of the backyard?". She does not understand science. The floor poly had some minor checking and a thinned coat of the same base over the surface made that disappear. The door with the oilbased trim and siding paint was perfect other than it had lost a bit of the gloss.So, I am with Bob - paint the door. My preference is the oilbased products. If you are predisposed to a waterbased use an acrylic rather than latex. One thing you will find when you go out shopping for your product is a lack of knowledge on the part of the salesperson. Not many of these folk are aware that their neutral or 4 base will dry clear. If you want to have some fun, spring it on them. They will suggest you are full of Donkey Dust. Ask them to shake a can and put some on a stir stick. Dry it and voila, it is clear." " Phantom Scroller and UncleApple 1 1 Quote
