Popular Post Rockytime Posted December 15, 2018 Popular Post Report Share Posted December 15, 2018 Steve Good mentioned that HD had 2x2" clear pine. I bought a length and it is exactly 3/4X3/4. Eight footer was about $12 with tax. So this is my first try with a Steve Good pattern. Started with an Olson #5 skip tooth but switched to a #7 Pegas MG. Still needs some sanding and de-burring. danny, bobscroll, RabidAlien and 13 others 16 Quote Link to comment Share on other sites More sharing options...
daveww1 Posted December 15, 2018 Report Share Posted December 15, 2018 nice job OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
RabidAlien Posted December 15, 2018 Report Share Posted December 15, 2018 That was my first compound, too! Its a fun cut! Steve's site recommends leaving the cutouts in place when flipping the piece over to cut the second side. I found that, for me at least, taking the cutout scrap OUT makes the second side easier to cut. I was worried about structural stability and my jig crushing the piece like an eggshell, but even with some of the very thin pieces (more scrap removed than wood remained) I've done, I never found that a problem. Never had an issue feeding my blade through the guide holes, and the reduced amount of wood to cut through meant that the second side was actually easier. bobscroll and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
bobscroll Posted December 15, 2018 Report Share Posted December 15, 2018 Great job there Les!!! Is it for the Wife? Thank you for letting us see, Bob OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted December 15, 2018 Report Share Posted December 15, 2018 Very well cut. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Foxfold Posted December 15, 2018 Report Share Posted December 15, 2018 Whoo Hoo, that looks brilliant. Well cut. I've never cut anything like that. Will look great with a finish. Don't forget to show us. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted December 15, 2018 Author Report Share Posted December 15, 2018 I have a clamp made from Steve Good's plans but I did not use it. Since there were no cuts going to the outside of the blank it was not needed. I normally drill my holes with the Dremel router attachment but discovered it would not drill deep enough so I used my drill press. 1/8" drill. PhotoWhit and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted December 15, 2018 Report Share Posted December 15, 2018 19 hours ago, Rockytime said: Steve Good mentioned that HD had 2x2" clear pine. I bought a length and it is exactly 3/4X3/4. Eight footer was about $12 with tax. So this is my first try with a Steve Good pattern. Started with an Olson #5 skip tooth but switched to a #7 Pegas MG. Still needs some sanding and de-burring. Very nice Les. Keep the pics coming. I love seeing what everybody is making. Rockytime 1 Quote Link to comment Share on other sites More sharing options...
CharleyL Posted December 16, 2018 Report Share Posted December 16, 2018 Looks pretty good, especially for your first attempt. I tend to use use smaller blades. They cut slower, but the cuts are smoother, resulting in less or no sanding. Sharp turns are less of a problem too. Compound cutting opens up a whole new world of scroll sawing. I have done very little flat work since first getting into compound cutting about 20 years ago. Be careful, it's a very slippery slope. Charley Jim Finn and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted December 16, 2018 Report Share Posted December 16, 2018 15 hours ago, CharleyL said: Looks pretty good, especially for your first attempt. I tend to use use smaller blades. They cut slower, but the cuts are smoother, resulting in less or no sanding. Sharp turns are less of a problem too. Compound cutting opens up a whole new world of scroll sawing. I have done very little flat work since first getting into compound cutting about 20 years ago. Be careful, it's a very slippery slope. Charley I haven't done too much yet but I can see from the small amount that I have done, it could become addictive. Quote Link to comment Share on other sites More sharing options...
spirithorse Posted December 16, 2018 Report Share Posted December 16, 2018 Nice work, Les, As already stated, a smaller blade than a 7 would be easier to cut with but, you did an outstanding job. I just cut that pattern recently and stuck it in my wife's Christmas stocking. I painted the words candy apple red and left the border natural. Thanks for sharing and God Bless! Spirithorse OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Jim Finn Posted December 16, 2018 Report Share Posted December 16, 2018 I have made this pattern also and I also like to use a #7 for wood this thick. One reason someone would leave the loose pieces in place while doing the second cut is that it keeps the cutting slower = more control. I sold the one I made, first time, I offered it for sale. I moved on to making toys/ornaments using this process, and have made and given away hundreds of those. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted December 17, 2018 Author Report Share Posted December 17, 2018 I also use a #7 Blade. For me, when I cut thick pine I use the skip tooth to discharge the sawdust more efficiently. When cutting pine with the grain the blade cuts much more slowly than against the grain. This is not so prevalent with hardwoods. OCtoolguy and Jim Finn 2 Quote Link to comment Share on other sites More sharing options...
Tomanydogs Posted December 23, 2018 Report Share Posted December 23, 2018 (edited) That’s great Les. You did a very good job. I love cutting the compound projects. Edited December 23, 2018 by Tomanydogs OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
