Rockytime Posted December 18, 2018 Report Posted December 18, 2018 I finished another of Steve Good's compound patterns. On a previous one I used 3M spray adhesive on the pattern and applied it directly to the wood. A quick dip in BLO removed the pattern and I just wiped off the remaining adhesive. I cut another one today but used a Scotch glue stick applying the adhesive to the wood and then applying the pattern to the wood. A lengthy soaking in BLO would not remove the pattern. No problem as it will come off on my belt sander. Others use glue sticks. I have to presume you use painters tape first. Is that correct? OCtoolguy 1 Quote
JTTHECLOCKMAN Posted December 18, 2018 Report Posted December 18, 2018 Well That would seem to be the answer yes. I always use blue painters tape on every project. I only use glue sticks when I am apply another pattern on top of a pattern. Makes it easier to reposition if i need to for better alignment. SCROLLSAW703 and OCtoolguy 1 1 Quote
Rockytime Posted December 18, 2018 Author Report Posted December 18, 2018 That's what I thought. Thanks for the reply. OCtoolguy and SCROLLSAW703 1 1 Quote
heppnerguy Posted December 18, 2018 Report Posted December 18, 2018 Rocky. I use different methods at different times. I sometime use painters tape with glue sticks. I rub the painters tape with the glue stick and also the back of the pattern with the glue stick, The pattern has never raised from the piece when I do I that way. No residue on the wood that way. I have also used spray glue only on the back of the pattern but I use paint thinner on the pattern face and wait about two minutes and the remaining pattern literally falls off the wood. If is does stick a little I will use a paper towel dipped in the paint thinner and wipe away the remaining residue. If I am in a hurry and do not wish to wait for the paint thinner to dry so I can start to put on a coat of finish, then I use the tape and stick glue. I buy the big glue sticks with the blue glue in them Dick heppnerguy OCtoolguy 1 Quote
OCtoolguy Posted December 18, 2018 Report Posted December 18, 2018 1 hour ago, heppnerguy said: Rocky. I use different methods at different times. I sometime use painters tape with glue sticks. I rub the painters tape with the glue stick and also the back of the pattern with the glue stick, The pattern has never raised from the piece when I do I that way. No residue on the wood that way. I have also used spray glue only on the back of the pattern but I use paint thinner on the pattern face and wait about two minutes and the remaining pattern literally falls off the wood. If is does stick a little I will use a paper towel dipped in the paint thinner and wipe away the remaining residue. If I am in a hurry and do not wish to wait for the paint thinner to dry so I can start to put on a coat of finish, then I use the tape and stick glue. I buy the big glue sticks with the blue glue in them Dick heppnerguy Is there a brand name on them Heppnerguy? Quote
MrsN Posted December 18, 2018 Report Posted December 18, 2018 I use glue sticks most of the time. On my own projects I put painters tape down, then glue stick. For the kids at school, most of the time I just glue stick right to the wood. The patterns usually peal off nicely. I use school type glue sticks. Currently Elmer's disappearing purple school glue. I bought a bunch when school supplies were on sale in the fall. OCtoolguy 1 Quote
neal560sl Posted December 18, 2018 Report Posted December 18, 2018 I have always just used rubber cement, then peel off pattern and remove residue with belt sander on all my ornaments. I mainly use rock maple and haven't had any trouble. When I was using cherry I did break a couple when sanding. OCtoolguy 1 Quote
scrollerpete Posted December 18, 2018 Report Posted December 18, 2018 You can get glue stick that are repositionable made by Elmer’s and available at Michaels and other stores. You can apply it directly to the wood and it comes off easy, not for intricate work as it comes off quite easy. I used it all the time for 3D cuttings I.e mini bird houses. OCtoolguy 1 Quote
Rockytime Posted December 18, 2018 Author Report Posted December 18, 2018 Thanks for the tips on Elmer's glue sticks. I'll pick some up today. The Scotch brand certainly did not work well. OCtoolguy 1 Quote
OCtoolguy Posted December 18, 2018 Report Posted December 18, 2018 Are we talking about Elmer's washable glue stick like for school stuff or is there another kind. I have that one in my desk drawer. Quote
Rockytime Posted December 18, 2018 Author Report Posted December 18, 2018 Katie said she uses blue school glue. I'm gonna go to Hobby Lobby and look for it. OCtoolguy 1 Quote
heppnerguy Posted December 18, 2018 Report Posted December 18, 2018 13 hours ago, octoolguy said: Is there a brand name on them Heppnerguy? it is Elmer washable school glue stick, I buy mine is the large 1.4 oz size and it lasts a long time. Just be sure and put the lid on when you are finished using it. Very inexpensive way to go and it works well. I have never had a problem with a pattern coming off even on intricate fret IF I put the glue on both my painters tape and the back of the pattern as well Dick heppnerguy OCtoolguy and scrollerpete 1 1 Quote
Rockytime Posted December 18, 2018 Author Report Posted December 18, 2018 I think I will try to use the glue stick for small patterns instead of spray adhesive. Spraying small patterns wastes alot of adhesive. OCtoolguy 1 Quote
scrollerpete Posted December 18, 2018 Report Posted December 18, 2018 2 hours ago, Rockytime said: I think I will try to use the glue stick for small patterns instead of spray adhesive. Spraying small patterns wastes alot of adhesive. Another thing to do is use clear packing tape on top of your pattern when you used the glue stick, it lubricate your blades and keep the pattern from lifting. OCtoolguy 1 Quote
scrollerpete Posted December 18, 2018 Report Posted December 18, 2018 3 hours ago, octoolguy said: Are we talking about Elmer's washable glue stick like for school stuff or is there another kind. I have that one in my desk drawer. Yes it is and it should also say repositionnable. OCtoolguy 1 Quote
OCtoolguy Posted December 19, 2018 Report Posted December 19, 2018 1 hour ago, scrollerpete said: Yes it is and it should also say repositionnable. Ah, the one I have doesn't say that. I'll have to make a stop at Hobby Lobby. Quote
ike Posted December 19, 2018 Report Posted December 19, 2018 When i cut fretwork I wouldn't consider blue painter tape. I have made shelves with 250 to 300 holes in them .Blue tape is a big pain removing on that type work so I use re positional spray glue directly on the paper , in fact I use it most of the time. I use mineral spirits to remove the pattern It's a lot easier IKE OCtoolguy 1 Quote
crupiea Posted December 19, 2018 Report Posted December 19, 2018 I use spray glue. I just use way way less/ I will use a super light spray, maybe 1 second per sheet. Then i let it sit for at least 15 minutes until its barely tacky, barely. then put it on the wood. stays in place, pulls right off when i am done. OCtoolguy 1 Quote
Rockytime Posted December 19, 2018 Author Report Posted December 19, 2018 Many ways to skin a cat! (Which is abhorrent to me) Very informative. Thanks everyone. OCtoolguy 1 Quote
tgiro Posted December 19, 2018 Report Posted December 19, 2018 Here is what I use for quick pattern glue-ups -- https://www.amazon.com/Removable-Restickable-Stick-49oz-Repositionable/dp/B001GXFB4K/ref=sr_1_2?ie=UTF8&qid=1545190528&sr=8-2&keywords=repositionable+glue+stick Scotch Removable Restickable Glue Stick, .49oz I spread the glue on the back of the pattern, then stick the pattern to the wood. Pattern peels off after cutting with no problems. If you let it set on the pattern for a couple of days you may have to sand it off or use some mineral spirits. Note - this is not my main way of gluing patterns to wood. I normally use the Xyron machine with the repositionable glue paper. The glue sticks are for one-offs and quick fixes. OCtoolguy 1 Quote
heppnerguy Posted December 20, 2018 Report Posted December 20, 2018 On 12/18/2018 at 5:04 PM, octoolguy said: Ah, the one I have doesn't say that. I'll have to make a stop at Hobby Lobby. Mine does not say that either and it works fine the way I use it Dick heppnerguy OCtoolguy 1 Quote
Rockytime Posted December 20, 2018 Author Report Posted December 20, 2018 I now have both types but I guess it is academic for me since I'll be using painters tape in the wood from now on. OCtoolguy 1 Quote
