I just finished sawing this (modified) Steve Good pattern and am looking for suggestions to best display it.
I recently dismantled a very early 1900's Singer treadle sewing machine. My wife wants the cast legs made into a table. I've salvaged all of the wood. I thought it appropriate to some of it on this wall hanging. It is constructed with 1-3/4 wide boards (oak, I think) with a 1/32" oak veneer of both sides. Thickness is 1/2". This is the hardest wood I've ever run into and sawing for this beginner was a task.
I wanted to leave the original finish. I'm not sure what the finish is but it is dark. And that's my problem. With the finish so dark the lettering and features kind of disappear. Thought about hanging it in a window to get backlight but doubt my DW will want it there.
I'm looking for suggestions on how to best present this piece.
Thanks, Tom
You could glue a backer on. Pretty simple.
It it were me I would glue a piece of 1/8" bb onto the back. Paint it white first.
Then once its dried just cut it to size right along the borders of the piece. It will only have one side but not the end of the world. This way you can keep the original dark wood and still have the cuts stand out.
14 hours ago, Scrappile said:
Great cutting.
Oh, don't look too close. There are some lines that I'm really happy with. But there are many that scream for a do-over. Fortunately my DW won't be as critical as I am.
Thanks for all the suggestions on completing this project. I don't have a large enough piece of BB for the backer so I'm trying picture mat board. Gloss white paint is now drying.
Tom
Tom
I have the same problem Tom. I'm very critical of my work and my wife tells me that "good" is "good enough". But, I don't see it that way. If I'm going to sign my work, I want it to be as near perfect as I can get it. By the way, you did a fine job on cutting this out.
Maybe use the crackle paint technique with an antique white as the top coat.  I also use the old Singer sewing machine bases to make tables.  I have made 2 and have 3 more waiting in the garage to do something with.
