Popular Post Rockytime Posted December 23, 2018 Popular Post Report Posted December 23, 2018 Soon as I saw Kirk's aka Rabid Alien I had to cut it. I had the pattern printed in red for these tired old eyes. I used 1/2" Cedar cutting it with a #3 Pegas MG blade. Now that it is cut I don't know what to do with it. I'll glue it to a backer but have no idea how to make a frame. I'm thinking of just getting some door trim and staining it. Hopefully I can make an adequate miter cut. JAC1961, John B, Scrappile and 10 others 13 Quote
Rohn Posted December 23, 2018 Report Posted December 23, 2018 That is very beautiful. I love it. Quote
wombatie Posted December 23, 2018 Report Posted December 23, 2018 Very impressive cuts Les, however you finish it I.m sure your will do it justice. Merry Christmas to you and yours. Marg Quote
Tomanydogs Posted December 23, 2018 Report Posted December 23, 2018 Well done Les. You did a great job! Marg is right, you will find the perfect way to frame it. Quote
Scrappile Posted December 23, 2018 Report Posted December 23, 2018 You certainly did a great job of that! Quote
Jim McDonald Posted December 23, 2018 Report Posted December 23, 2018 Great cut Les. Love the wood choice. Quote
smitty0312 Posted December 23, 2018 Report Posted December 23, 2018 Love it.....wood choice is excellent! Quote
RabidAlien Posted December 23, 2018 Report Posted December 23, 2018 Nice! Love the wood (cedar pollen is high today, so I would love nothing more than to cut something out of EVERY CEDAR TREE EVER!!! ). I found that when putting it on the backer, I made the frame, put the backer on the frame, then wrapped two rubber bands around the frame where the bottom of the letters would go, and used those to line everything up. I also cut the frame short enough that the music notes butted up against the frame. For me, made the spacing and layout much easier. Quote
Rockytime Posted December 23, 2018 Author Report Posted December 23, 2018 6 hours ago, RabidAlien said: Nice! Love the wood (cedar pollen is high today, so I would love nothing more than to cut something out of EVERY CEDAR TREE EVER!!! ). I found that when putting it on the backer, I made the frame, put the backer on the frame, then wrapped two rubber bands around the frame where the bottom of the letters would go, and used those to line everything up. I also cut the frame short enough that the music notes butted up against the frame. For me, made the spacing and layout much easier. I remember your rubber band trick. I'll use it. I went to HD today and picked up an 8' length of trim. I'll probably use up every inch of it before I get good corners cut. RabidAlien and amazingkevin 2 Quote
RabidAlien Posted December 23, 2018 Report Posted December 23, 2018 I grab the 1x2 poplar and usually go through about 4 times what is necessary to make one small frame. I also have been leaving off the dots over the "i", I salute your superior cutting skillz! Rockytime 1 Quote
amazingkevin Posted December 24, 2018 Report Posted December 24, 2018 I drooled seeing the music staff cut razor thin. You are G O O D!!!! Rockytime 1 Quote
