Downloaded a picture of a Chicago Bears Logo the other day and thought that I would try to cut it out.  It wasn't a scroll saw pattern so I knew that I would have to make changes.  It came out ok, but lots of head scratching prior to cutting it out.
I also used Pegasus blades for the first time on this piece.  The wood was 1/8" BB.  I used a #1 blade, not sure what type.  I ordered a sample pack from them.  My first thoughts,, I don't like the blade.  It's too aggressive to me.  I turned the saw's speed way down and still did't like it.  Maybe if I had stacked 2 pieces of wood it may have been better, but I think I will stay will Olsen for now.  It also left more fuzzies on the back than what I get from the Olsen's.
Yeah cutting 1 piece of 1/8" BB Pegas blades might be hard to control.   Like has been suggested a stack will help with the aggression of the Pegas blade.   What also will help is make sure the blade has reverse teeth.   Your piece did turn out real well thanks for showing us.
Mahendra aka multitom made a great portrait pattern for me. I enlarged it to fit an 8X10 frame and began to double stack it and cut with a #1 Pegas MG blade. The blade is super aggressive. I normally have the pattern done in red but being anxious to start cutting I went with my black pattern. My saw is running at less than 1/4 speed and yet I was having trouble controlling it. The problem was not the blade, the problem was seeing it. Because the blade is small it blends into the pattern for me. Even double stacking the blade cuts like a house on fire, fast. However, I do like the blade and if I distinguish it from the pattern it will work for me. Office Depot here I come.
Les, did you ever see the Steve Good video on how to use Inkscape and turn the lines red? It's not all that hard to do. Even I have done it and I have been fighting to learn Inkscape for a year now. If you are interested, I'll find the link to the video.
Ray, I have given up any intention of learning Inkscape. For me it is a waste of time. I would much rather scroll and do other things than spend time learning software. 10 minutes to Office Depot and it is done. Also they will enlarge t fit whatever I want. I just give them a percentage for enlargement and it is not only quick but inexpensive too. I admire those that use it and master it but i'm not much of a software guy. Rather use a wrench or a hammer.
If you have the link handy I would like to see it.  I'm like Les, not very good on learning the software, but I will give it a try. Is Inkscape a free download?
here ya go. But as Les said, there are a ton of great videos on youtube by Steve. And yes, Inkscape is a free program. So is Gimp. They both do many of the same things but differently.
Edited by octoolguy
cutting a single piece of 1/8" BB can be a challenge. I do it fairly often. I always use a zero clearance for cutting. Not much there to support the project at times. Using a fine toothed blade and controlling your blade and feed speed will help a ton. Like anything else it takes practice and patience when it comes to scrolling. Always remember this is fun and don't get too stressed out over things. Best of luck on your endeavor with the saw, wood and blades :)
