RDVawter Posted January 3, 2019 Report Posted January 3, 2019 3 minutes ago, redwine said: I have used the Insta-set that Trackman's photo shows except it was labeled for a hobby shop here but is the same item. The problem I have had using it is that while it cures instantly, it leaves the cured CA with a white coating that is very difficult to remove. If the part to be glued is hidden from view that is fine if not wait for the normal curing time. jmo. This has happened with 3 different super glues so test before hand! Erv I had this problem and was told it could be old accelerator. I bought new stuff and have not had the problem since. Have also been told that the glue and accelerator need to be the same brand, or you can have the same problem. Ralph JTTHECLOCKMAN and OCtoolguy 1 1 Quote
