Smitty Posted January 7, 2019 Report Posted January 7, 2019 It’s a simple one. I call it electric Heisenberg. The lesson I learned is to not use 1/4” stock. It limits the viewing angle a lot. lawson56, Falcon, RabidAlien and 6 others 9 Quote
stoney Posted January 8, 2019 Report Posted January 8, 2019 (edited) One way to increase the viewing angle on thicker stock is to spray the cuts the same color as the backer before removing the pattern. Your portrait turned out great. Thanks for showing us. Edited January 8, 2019 by stoney RabidAlien 1 Quote
Smitty Posted January 8, 2019 Author Report Posted January 8, 2019 Thanks for that tip. The backer on this is poster board. Then the back is another 1/4” piece, all glued together. I used my keyhole bit in the router horizontally for hanging so it will hang flush against the wall. Quote
rdatelle Posted January 8, 2019 Report Posted January 8, 2019 That came out good for your first one. Quote
amazingkevin Posted January 15, 2019 Report Posted January 15, 2019 On 1/7/2019 at 6:46 PM, Smitty said: It’s a simple one. I call it electric Heisenberg. The lesson I learned is to not use 1/4” stock. It limits the viewing angle a lot. How did Iknow this was going to outstanding!!!! Quote
