I put my new Pegas Chuck heads om my Seyco saw about Dec.1 2018. Love them. Yesterday the blade started slipping out of the top and bottom holders. I clean all my blades with spray brake cleaner and a cloth to remove any oily residue before using them I spent  hours trying to figure it out as I was trying to finish a project for a friend. Finally took the thumb screws out of my other saw and put them in. Fixed the problem. I would not think that the thumb screw sets would wear out so quickly. I have had them last on other saws for up too a couple years. I did take the allen screws out of the left side of the holders on the Pegas heads and they appeared to be contacting only about half the surface. The end of the thumb screws appeared to be worn as well. I could not find an address to contact Pegas.  Has anyone else had this issue with their Pegas chuck heads?
grizz
I had a feeling this would start showing up soon. The end of the thumb screw will have to be dressed. Lay down a sheet of 220 grit sandpaper. Very carefully sand the tip till  it is dull. I have a tip on doing this somewhere here, I’ll see if I can find it.
Ok, I don’t know how to create a link on my iPad. Go over to Works in Progress & Tutorials and look for Simple jig for blade slippage. I just bumped it so it should be on top.
Edited by dgman
Exactly. That and clean/sand the blades.
I understand how to do that but don't think it should be this soon. I have been scrolling over twenty years and have had to sand the ends before to get extra life out of the tips but not after three months and paying that much for something. Thanks for all the feedback and tips. I didn't realize there was that much difference between the Dewalt thumb screws and the Seyco/Excalibur ones. I believe I have a set of Dewalt as I used to have A Dewalt saw.  Still making sawdust anyway.
grizz
Dewalt screws are pretty darn good ones I think... Mine are the original ones that came with the saw.. I bought the extra set once and then found that Seyco sells just the tips.. then I read about the sanding the ends off.. so i did that and never used the new set screws or the tips.. BTW.. if you order the tips set.. don't do as I did and thought each set was for just the upper or lower, LOL a set includes both upper and lower... so since I haven't even wore out the originals.. I assume I should be good for many years on these.. LOL.... especially now that I end to use the Hawk more now anyway
For what it's worth.. when I talked with Ray about them.. he said they was all sourced from the same company.. at least back then.. so the DeWalt and Ex screws was made by the same company... I'm guessing the Delta too?
BTW, I do agree with you about the price and the fact that they shouldn't be getting worn out already.. But I also am betting that Pegas didn't actually make these.. possible a bad batch went though or the company that made them maybe got a bad batch of steel.. I hope this isn't going to be the normal for these.. you know... it seems every company tries to cut cost and cheapen things up...
Edited by kmmcrafts
Yes they do seem to take short cuts and cheapen things up Kevin. They also seem to have control problems and run bad batches of items as well. I already have several extra sets of tips I recently purchased from Ray. I must have been anticipating needing them. I must need to take more time sanding down the old ones as I seem to not get them flat and they don't last very long. Well I got my griping out of my system for a bit back to the saw and making sawdust. thanks all for the input.
grizz
It's been quite a while back........I believe it was Steve Good...........drill a hole a touch smaller the the screw in a piece of wood about 1/4" thick ........screw the screw in until it just barely come out the other side..........then sand it with a sander.  Works good. I used to do it when I had my Dewalt.
This is from Ray @ SeyCO - it works great and I use it regularly when I have blade slippage in my clamps.
1.  Use a piece of scrap - 3" x 2" x 3/8". Drill 7/32" holes, about an inch apart, on the center line of the board.
2.  Screw the setscrew and thumb screw into the board until the ends are just flush with the other side of the board.
3. Lay a piece of 220 grit sand paper on a perfectly flat surface. Place the board on the sandpaper with the screw ends down.
4.  Rub the board around on the sand paper until the screw ends are shiny and any nicks or dents are removed.
Remove the screws from the board and replace them in the saw. Pay attention to the alignment. I use feeler gauges to set the setscrew 1mm proud of the left side of the blade gap, in the clamp. Do that on both upper and lower clamps.
I do this as part of my semi annual maintenance drill. Even when I haven't been having slippage in the clamps. I did this on my old DW788, on the OEM clamps on my EX-21 and I do it on the Pegas clamps.
Note - The thumbscrews from the DW788, The Excalibur saws, and the Pegas clamps are interchangeable. The setscrews are, also, interchageable. but the Dewalt and Excalibur setscrews are not long enough for the locking nut that Pegas uses. I do not know about the new versions of the Excalibur design - King, Axeminister, Seyco, or even the new Excaliburs.
Seyco sells the setscrews and tips for the thumbscrews as sets. The thumbscrew tips fit the Dewalt and Excaliber thumbscrews, but I haven't tried them in the Pegas thumbscrews.
Thanks for the information on how to sand the tips, I will use that. Also never though of the feeler gauge trick, I am going to try that as well I think that will help,  I had some new tips on hand purchased from Seyco. Actually the company I purchased my Pegas chuck heads from are sending me new tips to replace the other ones. The tips I have from Seyco seem tp fit the Pegas thumb screws just fine. I will see if there is a difference when I receive the Pegas ones. I don't think there will be.
grizz
