Popular Post Foxfold Posted January 31, 2019 Popular Post Report Posted January 31, 2019 Having done my own pattern I had to make adjustments to both the 'cogs' and the base to make the 'figure' fit and the napkins fit nice and I also folded them as @innar20 suggested. However I'm really pleased with the end result. As you can see from the 'before' and 'after' photos a little paint and some better technique makes such a difference. loftyhermes, RabidAlien, spotsdad and 14 others 16 1 Quote
Fab4 Posted January 31, 2019 Report Posted January 31, 2019 Hi Brenda Well done What is the overall height of this Thanks for showing us Fab4 Quote
Foxfold Posted January 31, 2019 Author Report Posted January 31, 2019 43 minutes ago, Fab4 said: What is the overall height of this 10¼" including base. Fab4 1 Quote
rdatelle Posted January 31, 2019 Report Posted January 31, 2019 That looks much better Brenda. Are there any patterns around to make this. I would love to give it a try. RabidAlien 1 Quote
Foxfold Posted January 31, 2019 Author Report Posted January 31, 2019 (edited) 1 hour ago, rdatelle said: That looks much better Brenda. Are there any patterns around to make this. I would love to give it a try. This one I made myself I'll try and add it here, later Edited January 31, 2019 by Foxfold Quote
JTTHECLOCKMAN Posted January 31, 2019 Report Posted January 31, 2019 These are going to be added at my shows this year for sure. Love this idea. Quote
Foxfold Posted January 31, 2019 Author Report Posted January 31, 2019 (edited) Ok, never tried this before, but nothing ventured nothing gained. Let me know if you can see/work with it. The base is just an Oval with a slot cut in it to fit the lady. I have the pattern if needed. LadyFor Forum2.pdf Edited January 31, 2019 by Foxfold Fab4 1 Quote
JTTHECLOCKMAN Posted January 31, 2019 Report Posted January 31, 2019 2 minutes ago, Foxfold said: Ok, never tried this before, but nothing ventured nothing gained. Let me know if you can see/work with it. The base is just an Oval with a slot cut in it to fit the lady. I have the pattern if needed. ssv.svg can not open Quote
Foxfold Posted January 31, 2019 Author Report Posted January 31, 2019 6 minutes ago, JTTHECLOCKMAN said: can not open Ok, went on the Internet to find a way of making it a pdf. Fingers crossed I've got it right this time. Quote
JTTHECLOCKMAN Posted January 31, 2019 Report Posted January 31, 2019 28 minutes ago, Foxfold said: Ok, went on the Internet to find a way of making it a pdf. Fingers crossed I've got it right this time. That one did work. Thank you. Keep up the good work. love these. Quote
Ivan Nikolaev Posted January 31, 2019 Report Posted January 31, 2019 27 minutes ago, JTTHECLOCKMAN said: can not open https://www.ilovepdf.com/ Try these links. Adob reader must be freehttps://get.adobe.com/ru/reader/otherversions/ Foxfold and Fab4 2 Quote
innar20 Posted January 31, 2019 Report Posted January 31, 2019 Painted is a lot better! Thank you! Foxfold 1 Quote
Gordster Posted January 31, 2019 Report Posted January 31, 2019 You have it down to perfection now Brenda...paint is great...thanks for pattern. Foxfold 1 Quote
Rockytime Posted January 31, 2019 Report Posted January 31, 2019 I'm just impressed with your talent Brenda. Foxfold 1 Quote
Tomanydogs Posted February 1, 2019 Report Posted February 1, 2019 Well done Brenda. You can add pattern designer to your profile. Quote
wombatie Posted February 1, 2019 Report Posted February 1, 2019 Brenda, how does she stand up? is she balanced on the small block at the bottom of the dress or am I missing something. Marg Quote
Foxfold Posted February 1, 2019 Author Report Posted February 1, 2019 2 hours ago, wombatie said: Brenda, how does she stand up? is she balanced on the small block at the bottom of the dress or am I missing something. Marg Marg, she has a 'tab' at the bottom that fits into a 'hole' in the base. wombatie 1 Quote
Foxfold Posted February 1, 2019 Author Report Posted February 1, 2019 4 hours ago, Tomanydogs said: Well done Brenda. You can add pattern designer to your profile. Aww bless you for the thought. I'm not sure cutting out a silhouette constitutes 'pattern maker' but I thank you for the compliment xx Quote
rdatelle Posted February 1, 2019 Report Posted February 1, 2019 21 hours ago, Foxfold said: Ok, never tried this before, but nothing ventured nothing gained. Let me know if you can see/work with it. The base is just an Oval with a slot cut in it to fit the lady. I have the pattern if needed. LadyFor Forum2.pdf Thanks Brenda, I printed it out. What size wood are you using. Quote
Foxfold Posted February 1, 2019 Author Report Posted February 1, 2019 23 minutes ago, rdatelle said: Thanks Brenda, I printed it out. What size wood are you using. The black one is ¼" mdf, the 'wood' one is ¼" ply. Quote
rdatelle Posted February 1, 2019 Report Posted February 1, 2019 4 hours ago, Foxfold said: The black one is ¼" mdf, the 'wood' one is ¼" ply. Thanks Brenda, I figured that might be the size. Quote
jerry1939 Posted February 1, 2019 Report Posted February 1, 2019 On 1/31/2019 at 9:51 AM, Foxfold said: Ok, never tried this before, but nothing ventured nothing gained. Let me know if you can see/work with it. The base is just an Oval with a slot cut in it to fit the lady. I have the pattern if needed. LadyFor Forum2.pdf THANK YOU for my copy Friend' jerry Quote
Foxfold Posted February 1, 2019 Author Report Posted February 1, 2019 1 hour ago, jerry1939 said: THANK YOU for my copy Friend' You are more than welcome Jerry, I hope it works ok. Quote
